Probelms with Lionel TMCC Power Master in Conventional mode
My layout is set up for Lionel TMCC and uses a Power Master so that I can run in Conventional mode. It runs fine in Command mode, but when I move switch to “Conventional” mode nothing happens. I have tried reprogramming the Power Master (as suggested by Lionel) but this doesn’t seem to correct problem. Any suggestions?
Be sure the crystal is seated firmly in the PM-1. Set the TR ID to #1 following the manual. Be sure to set the PM-1 to “program” and use the “set” key behind the CAB-1 door. Move the switch to “run”. Re-address TR#1 and hit “boost”.
Set the momentum to “L”(low).
Check the troubleshooting manual.
Rob
I had an engine that messed up and jumped the track and it fried the powermast instantly so if you had that it will just work as a way to arr power to your track from your brick
