problem with a set of Lionel 6-31791
Hello! There was a problem, bought a set of 0-scale launch (LEGACY FREIGHT SET 6-31791). Ride an hour and a half, then got up and no makeup does not respond. Management of CW-80. Trance on the green lamp lights up (like everything is OK), locomotive speed control does not respond, the sound is not only changes the amount of light (number) front and rear lights are off.
I tried to swap the wires to the rails, the sound is working (but on its own), front and rear lights are off, the cabin lights are off, lit only license plates, the locomotive does not go.
How to solve this problem?
Check your paper work and contact Lionel customer service…
Try a differant type of transformer as the CW-80 might be your problem. The CW-80 puts out a different type of electrical wave form then the standard Lionel transformers like the ZW’s or KW.
i cant. i have only cw80.
