Hello All,
Thank you for letting us know your timeline on responses and that you are not “ghosting” us.
A few questions to consider and reply to:
- Did this happen “all of a sudden” with no changes in the electrical load?
- Did you add/change anything?
- What is the maximum Amperage output of the 18-volt side?
The “load” (Amperage) of the lights should be determined to understand if you are overloading the capabilities of the 18-volt circuit.
Most electrical devices will list on their specifications not only the voltage but also the amperage.
OK, I’ll try to explain this in the simplest terms possible (Others with practical electrical knowledge feel free to chime in).
If this is too pedantic please excuse me.
With electricity, there are three parameters: Voltage (V), Amperage (A), and Hertz (Hz).
Unless you are dealing with European electrical equipment Herts is not a factor. North American power runs at 60 cycles per second or 60Hz.
Most North American electrical grids are based on 110 to 120 Volts. Again, not a problem unless you are dealing with European components.
Amperage is determined by the “load” or electrical “force” necessary to push the electrons to power a given load. Also known as “draw”.
When the breaker in your home “Trips” or faults, it’s the Amperage that is causing that to happen- -not the Voltage or Hertz.
For example: If you put three components that “draw” 5 Amps each your “load” is 3 x 5 Amps = 15 Amps.
If the circuit breaker is rated for 15 Amps you have reached it’s “limit” or potential.
When you add a fourth component rated at 2 Amps you have exceeded the Amperage of the breaker and it will trip or “fault”.
The more often the breaker trips it physically takes a toll on the electric
