I’ve been using four BLI Blueline locos on the same train for months. Just recently they have started giving me trouble. At the very slowest speeds (1 to 4%) any one of them will stall (no power). After a second or two it may come back on. A lite whack of the benchwork is all that is needed to make connectivity again, and then stop. Touching one of the trucks slightly produces the same result. They also are not running as smoothly (somewhat jerky, even at speed soemtimes) (running solo). Sometimes, when this intermitent contact occurs, the horn or bell may sound, or the engine sound level changes on it’s own.
I’ve added lubrication to through the worm gear housing (LaBelle107). And I removed the worm gear housing on the rear truck just to check for any resistance or uneven motion manually turn the wheels and motor and I can’t detect any.
One of the four was purchased brand new. They all do the same thing. They worked fine for a few months. And yes, the wheels and track are immaculate clean.
The best I can tell is that this has something to do with how the wheels/trucks are running/riding on the track. The slightest touch of the truck will get power to the loco.
Here’s an additional thought regarding the above issue:
Upon close inspection after partial disassembly of the rear truck I notice that there seems to be a little too much play between some of the axles and the the bearings. The bearings have a copper “leaf” (spring?) that performs the electrical connection from the wheel/axle to the central wire for all three axles. It’s as if there’s not quite enough “pressure” and/or the axle doens’t fit closely enough all the time to make an electrical connection.
I’m wondering if this is a climate/temperature issue. The layout is in the lower level of my home, partially below grade. Ever since we had the new “energy efficient” HVAC installed, its been quite a bit colder downstairs during the summer. The AC fan doesn’t run as fast (supposedly to remove more humidity) but the slower fan speed also doesn’t pull the denser heavier cold air out of the lower level as well. It’s actually much warmer down there in the winter than in the summer.
I didn’t have these kinds of issues during the winter. I’m wondering if it’s cold enough down there now to cause the loco parts to contract just enough so that certain components are making intermitent contact.
Just for kicks I’ve taken the loco thats been giving me the most trouble and put it in the garage where its hot & humid. After a day in there I’ll try this again and see what happens.
I think you might be on the right track (pardon the pun) when you talk about the power pickups being the problem. My first action would be to clean all the contacts. Using an electrically conductive lubrication like CRC 2-26 might help too.
I doubt that the temperature would have much to do with the problem because the parts are so small. The amount of expansion or contraction would be extremely small. I could be wrong, but in any case, putting a little more tension on the contacts might help. Note that you don’t want to overdo the tension. Too much tension could add some drag to the mechanism.
Well, the colder temperature/humidity causing contraction of the parts to make a good electrical connection wasn’t the issue.
Some clarification of my initial post: Four locos involved. Three are C30-7 and one SD40-2. The SD40-2 was purchased new. After restesting all four locos individually and under different conditions/parts of the layout, the SD40-2 appears to be fine. But all three GE C30-7 have connectivity issues at slow speed.
I disassembled more of one them. The “leaf” (spring?) I mentioned is actually a copper bar that slides onto the back (inside) of the plastic truck clasp. The motor wire(s) are soldered to this copper bar which is also the bearing for all three axles.
I guess I’m wondering if lubrication such as regular good ol’ LaBelle 107 can eventually cause electrical issues as it eventually gets a little dirty in the bearing holes and on the axles.
Had a talk with BLI tech support. It’s definitely a dirty axle/bearing issue. He said when they get these in for repair they clean the bearing holes in the copper plate and axle contacts with a electrical enhancement lubricant. He also mentioned cold solder joints that sometimes need a touch up.
That was certainly the case here. Two wires, one from each truck broke off very easily upon disassembly. I cleaned all the old oil off and used Deoxit Gold, similar I’m sure, to what Dave recommended. I’ve used this stuff for years on my audio equipment. Looks like I’ve found a new use for it.
I put a little train grease on the worm gears, gave the wheels another cleaning, and everything seems to work fine so far. The motion is still not as smooth as I would expect but I’m hoping after the grease works its way around all the gears this will smooth out with some time.
This is quite a bit of maintenance to get these locos back up to par. OTOH I guess that might be one of the reasons BLI discontinued Blueline. I sure hope all the Paragon2 locos I have don’t require the same maintenance as that will certainly add to my “pain” list for DCC.
My best recommendation is to NOT lubricate the axles on these locomotives with conventional oils.
ALL locos need periodic maintenance like that. Old grease gets hard, and grease and oils attract dirst which must be periosically cleaned. Any surface involved in the transfer of power from the rails to the electronics needs to be kept clean so that means cleaning wheels and then, depending on how the loco is made, either pickup wipers and the part of the wheel or axle the rub on, or bushings at the ends of the axles, or some other system.
It’s not good to run bearings dry. The oil must be used sparingly though, the tinest of needlepoint drops is all that is needed. Too much and it runs down on the wheels and track and only makes a mess. Yes, eventually it will start attracting dirst, and then it’s time to run through the shops again.
Most all Broadway locos follow similar design, as do most other brands. Power transfer through axle bushings is a tried and true method, going back at least to the early Athearn Blue Box locos and widely copied. Axle wipers on trucks, especially on steam loco tenders, is common across pretty much every brand as well. Rivarossi has used it for years, Bachmann too, and Broadway.
“ALL locos need periodic maintenance like that. Old grease gets hard, and grease and oils attract dirst which must be periosically cleaned.”
No Kidding.
That’s not my point.
I did not say to NOT use any lubricant. I said to “NOT lubricate these locos with conventional oils”.
Unfortunately, I don’t see any where in the BLI user or technical manuals or any other documentation that even mentions anything about what kind of maintenance is required to keep these locos fit for trouble-free DCC operation. And there is no mention anywhere of using lubricants such as CRC 2-26 or DeOxit which act as cleaners and conductivity enhancers. Yet when I spoke with BLI tech support, that is the first thing he mentions that they do when these come in for repair.
Furthermore, my point is that this kind of, and frequency of maintenance was never required with DC. I installed DCC 9 months ago. And that was after upgrading and rebuilding the entire layout with new track, turnouts and wiring, all to overkill standards so that everything would be more than more than capable of handling trouble-free DCC operation. And yet the result is I’ve had more issues in the last 9 months than I had in the previous 30+ years on this layout with DC.
Table thumping was an ART back in the day. When all I had were train set quality locos that picked up (most of the time) with just 2 wheels on each truck, and the track was all brass, I quickly became an expert at exactly where and how hard to thump the layout to restart a stalled loco.
If anything, poor pickup caused MORE issues with DC, because running at reasonable speeds meant far less voltage on the rails than the steady state DCC voltage.
Yeah, well read my post again. I said I did not have to do this kind and as much maintenance as I did with DC, with the same locomotive, on 30+ year old track with sub-grade (read: inadequate) wiring.
I disagree. I never had to thump anything, on the same layout, with old worn out track and inadequate wiring on a 30+ year old layout with DC. Nor did I have to maintain everything squeaky clean in order to just turn it on and run trains. And therein lies the problem with DCC. Surely, by now, in this day and age, components can be designed that can overcome the ridiculous level cleanliness and maintenance required for consistently reliable DCC operation.
Thousands of people run DCC with far fewer problems than you have described – or it wouldn’t be as popular as it is. I’ve been able to run DCC in N scale (with a smaller wheel contact area) in a garage with fewer problems than you have described.
There are several products they make in addition to this such as ProGold GX. They can be kind of pricey but you can get it for much less at places like Guitar Center (have to order) or Amazon or Ebay.
I’ve used this for decades on high-end audio equipment and it works like a charm. It actually improves audio quality. And it worked like a charm on the aforemetioned loco. It’s running with no connectivity issues now.
This is the oldest of the 4 locos in this consist and it was purchased used. The previous owner apparently used too much (conventional) oil which eventually, as it got dirty, contributed substantially to several issues I’ve had with it. Now (so far ~ knock-on-wood) it’s running solo, or in consist, pulling 30+ car train over hilly curved terrain at the slowest speeds, or at speed without any stuttering or connectivity issues.
…or, as I have done for a decade now, use Dexron III Mercon ATF. It’s an excellent lubricant, paint safe, plastics safe… I have been using the last couple of tablespoons left in a plastic bottle probably 20 years old now.
That’s what I’ve used also. It’s also contributing to the problem. The LaBelle oils are NOT electrically enhancing, they don’t improve conductivity or prevent future oxidation as much as products like DeOxit do. Since DCC is so sensitive to these issues it’s best to use something that actually improves performance IMO.
Frankly, the only time I have power issues is on the club layout with the bridge sections between modules, the joiners are the only power source and everyone runs at least doubleheaders with diesels because one unit WILL stall, unless it has a keep alive cap. None of my locos have keep alives, and they don’t stall on my home layout.
