Problem with my Zephyr
Hello,
when I went to run an engine this morning I noticed that it keeps running even
when I flick the lever to brake on my zephyr. The brake light doesn’t blink
either. It worked fine yesterday. I can stop the engine only by turning down the throttle.
Can anybody help me out
Thanks
Art
Art, I think you will find that the switch controlled by the knob has broken. Very likely that you will need to call Digitrax and have it sent in for repair. They are generally very good at turning these things around within a couple of weeks.
If you swing it all the way around to reverse, does the engine reverse direction, or does it keep going forward??
It reverses like it should
Did you try a reset? Prog Switch 39 c?
David B
Hi. I have had the same problem. It behaves like it has a mind of its own. I turn power off and unplug. Sometimes I have to do this a couple of times but it always works
It sounds like you have somehow accidentally turned the braking feature off.
From page 15 of the Zephyr manual:
