Problem with Reverse Loop
Hello guys. I’m new here and looking help from all you guys who I can see from reading here you know a whole lot more about this than I do. Can you give me some help sorting out an issue with my reverse loop? I have a small 4 X 8 N-Scale (DCC) layout. Recently upgraded from Bachmann E-Z Command system to NCE PowerCab. Upgraded the wiring which is a bus panel for the main tracks (4 divisions) and a separate bus for the single reverse loop. I have a problem now that my PowerCab powers up and immediately shuts down whenever the reverse module is connected. It worked fine before the wiring upgrade, which involved just adding more track feeder wires and upgrading the bus wires from 20 ga to 16 ga. Also put the reverse loop on a bus. I replaced the Bachmann auto reverse loop mod with a Digitrax AR-1. I’ve checked and rechecked all wiring for shorts countless times, and resolved all of that. A DC powerpack works great over the entire layout (as long as I don’t cross from main track to reverse loop). If I place a loco on the reverse loop it runs like a champ. So no apparent shorts anywhere. But PowerCab will not remain powered up when the reverse loop is in the circuit, unless I disconnect the auto reverse mod, power up the PowerCab, and then connect the reverse loop mod, everytime I power up the layout. Had the same issue with the Bachmann reverse module also. I sure hope you gurus can tell me what I’m missing here. Thanks,
Trainwrek
You didn’t say much about gaps. More info there may help. Also, describe how the reversing section is configured as far as the track arrangement.
All feeds to that reverse loop must come from after the autoreverser, so if you have a bus running to the loop feeders, it needs to come from the output of the AR1. The input of the AR1 would connect to the bus that feeds the rest of the layout. And you need the proper gaps, if it’s a diagonal that cuts across a basic oval, both rails of both diverging sides of both turnouts need gaps - 4 gaps total. All feeds between the gaps must come from the loop bus and not the main bus.
The separate power bus you mentioned must feed its power into the reversing module ONLY. The reverse loop track should get its power ONLY from the reversing module.
Be sure the reverse loop track is fully insulated from your remaining track–both rails at both the loop entry and exit points–that is four gaps. If it still does not work, there are crossed wires. Try switching the AR-1’s out put wires and see what happens. (May we assume the loop track is long enough to accomodate your longest train?)
I think that it has all been said in the first three replies, so I will only reiterate it all here.
A reverse loop (or reversing section) must be completely isolated from the rest of the layout by creating gaps or insulated rail joiners in the rails.
The auto-reverser must be powered on the input side from the main bus or from a sub-bus powered independently from the reversing section.
All feeder wires inside the reversing section must be connected to the output side of the auto-reverser.
No feeder wires from outside the reversing section can be connected to the auto-reverser.
No feeder wires from inside the reversing section can be connected to the main bus or sub-bus.
So, apparently, you have insufficient gaps, crossed feeder wires, or misconnected feeder wires.
I got the problem fixed! Reversed the 2 input wires from the main bus to the AR-1 and the short was eliminated. Thanks everyone, for all your feedback.
Trainwrek
That’s rather curious because it shouldn’t matter which way the two wires from the main bus are connected to the input side of the AR-1. Flipping them should make no difference.
Yes, that is rather odd, since all the AR-1 is really doing is flipping the order of those connections as needed. Powering up with nothing across the reverse loop gaps, it won;t matter which way it’s connected. When the first train enters the loop, either you “luck out” and it’s already matching polarity, or the AR-1 flips connection. Then when you exit the loop, it flips again to match at the exit side.
Now if the input and output lines were mixed up, that’s a different story.
I completely agree. After all it is AC. But that is exactly what I did and it is working now…Not sure what to think about this. Any thoughts from you gurus? I’m perplexed and expect to find a problem somewhere else related to it at some point.
And, of course, it is more than luck. Whenever you have a reversing section (or loop), once reverse polarity is encountered and corrected by the auto-reverser, the polarity will change once again after a train enters the reversing section from the opposite end. As it exits the reversing section, the polarities will now be mismatched, causing the auto-reverser to flip the polarities once again.
Well, by ‘luck’ I mean if you happened to get it wired correctly, the very first time you entered the reversing section nothing would happen, because it would already match. After that it depends on which way the trains enter and exit. If you exit the diverging side and the next train enters the diverging side, it will have already been set correctly by the exiting train and again nothing happens, but if you always go the same way around, it will have to flip every time a train enters and leaves.
So, how has it been working? Have you tested it, running trains in every direction over every possible path?
I’m concerned about your statement that you upgraded the track bus. That was a good thing to do, of course, but you have to be careful because every wire gives Mr. Murphy another opportunity under your layout. A wrong feeder to an industrial siding, for example, might not show up for a while until you run a switcher down there to pick up a box car.
If it works now where it didn’t work before, whatever you did apparently fixed the problem. Who knows, maybe one of the wires on the input side was not solidly connected. That would do it. Let us know if future problems develop.
You guys were all over it. I guess I spoke too soon. I must have just run a train into and out of the reverse loop from one direction, because last night I attempted to enter and exit from the opposite end of the loop and hit an immediate shut down (short) every way I attempted it. Checked everything, even checked to see if a cut lever on the locos might be dragging of the turnout frogs or something like that. No luck. No adjustment of the AR-1 resolved the problem, and another look at the wiring orientation and rail gaps in all the required places turned up nothing. So I am at a total loss right now… Totally odd how reversing 2 wires on the AR-1 input leads would suddenly allow a loco to enter from one end when it wouldn’t before. Somehow that must have fixed a local short, but something is preventing the AR-1 from tripping at all. What is your take? The up side - maybe I’ve made a little progress; the down side - I still haven’t gotten anywhere…
If reversing the two wires allowed a train to go in - that tells me you only have 1 rail gapped, or there are main line feeders connected to the loop. Can you post a track diagram and show where your gaps are?
It’s not odd at all. Flipping the two wires wasn’t the issue. The issue was that matched polarites occurred on the entry into the reversing section but mismatched polarities occurred upon exit out of the reversing section. And, of course, entry and exit are defined by the direction of the locomotive.
As Randy just said, either your feeder wires are screwed up or your rail gaps are wrong. Insufficient gaps or misplaced gaps will do it. Feeder wires will either be crossed, sourced wrong, or connected in the wrong place.
How about posting a track diagram?
Edit Note: Here is a repeat of my earlier reply.
Trainwrek, here are some further thoughts for you to consider.
  1. Rail Gaps. A reversing section must be completely isolated from the main layout. That means that there must be sufficient rail gaps, and the gaps must be located in the proper places. So, do you have sufficient gaps and are they appropriately placed?
  2. Feeder Wires. The AR-1 is powered by a pair of feeder wires from the main bus so that power to the input side of the AR-1 is from outside the reversing section. Any all feeders connected to track inside the reversing section must be connected on the other end at the output side of the AR-1. No feeders from track outside of the reversing section should be connected to the AR-1. How many pairs of feeder wires are connected to track inside the reversing section?
  3. AR-1. While not a likely culprit, it is always possible that the AR-1 is not adjusted correctly or that it is defective. Once you confirm that the gaps and feeder wires are installed correctly, it will be time to hone in on the operation of the AR-1, but not before.
Randy, I will attempt to upload a track diagram. This will be my first attempt so give me a little while to see if the file I have can be uploaded here. Be right back to you.
Ken
(Trainwrek)
Rich, I am using email to reply because I can’t figure out how to attach the file one the forum. I have attached a copy of my layout map showing the rail isolators. Keep in ind my earlier post in which I said I had used the Bachmann EZ Conmmand system with this layout without a hitch, before I added more feeders and upgraded the bus wires. So rails were already gapped and worked without a problem before. There are now 11 sets of feeders to the reverse loop. Loco will enter or exit the loop from the point where it intersects the mail (Div 2) and the front of the layout, but shorts where attempting to enter or exit from either of the 2 points in the rear.of the layout (switches 6/8 or 7/9)
I was thinking the AR-1 was not sensitive enough because a two loco consist was only drawing about .21 - .23 amps and the info sheet with the AR-2 says the lowest trip setting is about .25 amps. I ran the consist through switches 6/8 and they stalled over the rail gap - one loco on each side (not surprising). What was surprising was the system did NOT short out, but the lead loco still had the headlight on, the rear loco back-up light came on. In other words they seemed to be showing opposite polarities. I’m guessing the lead loco was pushed far enough to get past the gap before they stalled, but why no short if they were picking up opposing polarities? They would not respond to any input but NO short. PowerCab did not shut down!! I’m thinking a short still exists back there some where but for the life of me I cannot find it Really perplexed by the fact that the system did not short out and shut down. My patience with it IS starting to short circuit, though. I
One last post before I put this thing to rest while I try to raplace my reserve of patience, which is completely depleted now. I have run this layout wired just like it is now on another DCC system without these problems for over a year. I just installed bus wires (and a few more track feeders) to improve the way trains run and more safely accomodate the more powerful NCE DCC system (PowerCab). Wherever I put new track feeders I have checked and re-checked countless times to make sure the po;arity is consistent throughout. It is. I’ve rechecked ALL the wiring and it is still as it should be. I’ve now disconnected feeders that I thought might be suspicious in any way. No change. Every wire on this layout is connected as it should be and every gap or insulator is where it should be (has been for almost 2 years). But the AR-1 is simply not tripping, regardless of how it is adjusted. I have reinstalled the old Bachmann EZ Command reverse module, and it is not tripping either. I am abdolutely certain the reverse loop power distribution panel is wired correctly and isolated completely from the rest of the layout. So I’m near the point after spending almost another entire day on this problem of relegating this layout to a static display. That won’t last long because I don’t have the space for an 8’X10’ museum piece. I will either find a solution or dismantle and sell this thing, soon. But now that I have vented a bit, I will think on it for another day or 2 (and await some breakthrough idea from one of you guru’s). Then I’ll give it one more try before I start donating stuff. One thought of clarification - the entire reverse loop is wire to separate power distribution panel, with bus wires to each of the track feeders. The Input side of the AR-1 powers the reverse loop power distribution panel. For what it’s worth…
