Problem with Soundtraxx DSD 101 LC
After the summer break I have a new problem: My Con-Cor M-10000(H0),and also the Zephyr(H0) has a Soundtraxx DSD 101LC-Decoder.Till the late spring they runs fine,but now-if it run´s and I will take the Horn-they stops and then runs??? Reset was without success-What can I do,did anyone know this effect? My digitalsystem is Digitrax. greetings from Germany,Steffen
It could be one or more of the following. Dirty track/corrosion, same with wheels and pickups.
Yes, they may look clean. Start with the track.
Steffen, I have never encountered this phenomenon. If I have problems with dirty track, or dirty pickups, the sound decoder usually just stops. No sound, no motion.
Are you absolutely certain your reset was complete? Did the loco only respond to Address 03 afterward?
I think that, in the end, you will decide that the decoder is defective…but not if both decoders are doing the same thing. If both decoders are doing this, it must be the throttle or the base station. Unfortunately, I can’t help any further.
-Crandell
