Problems with EZ Command
I have a Bachmann EZ Command DCC system and when I finally was able to set it up and run a N scale engine it started making a squeling/hissing noise. The engine (a N scale bachmann NW Jclass) runs, but whenever there is power to the track the engines make a strange noise. I tried running some HO scale engines on some other track with the same result. Does anyone know what might be the problem.
[#welcome]
Are you sure the engine has a decoder in it?
Sounds like your locos don’t have decoders. You can’t just hook up a DCC system, throw an ordinary loco on the track and expect it to work. The loco must have a DCC decoder.
Thanks. The EZ Command has an address that can be reserved for engines that do not have decoders. Do you think I would not have this problem if it did? Again the engine runs fine, but it makes a screeching sound and I worried its damaging the motor.
The address on the EZ-Command for running a DC loco is 10. What address are you using for your loco. If it has a decoder it should be an address from 1 to 9. There are only a couple of reasons the motor would shriek while running with the EZ-Command. One is that it the loco has no decoder, just a light board. The other is that it has a bad motor or drive. If that’s the case it should shriek when run on DC also. Now, what address button do you have to press to run your loco? If it runs only when the ‘10’ button is pressed the loco has no decoder, which from the sound you describe and the fact that it does it with other locos seems likely. If it’s a button from ‘1’ to ‘9’ then you have a more serious problem. The possibility of it being a wiring problem with the EZ-Command is virtually nil. The connectors fit only one way. I know about this type system. I used one for two years with no problems.
If the engine sings and groans and buzzes, but moves when you give the throttle a substantial turn, it means the engine is just fine, and so is the EZ-Command. It also means, as other gents suggest, that the perfectly fine engine does not have a decoder in it. The singing and groaning is the motor responding to current pulses that it was not intended to receive because those pulses come at the frequency of the digital track impulses put out by the EZ-Command…and all other DCC systems.
Or…
You have one of two other possibilites: plastic or metal rubbing on something it shouldn’t, creating a harmonic resonance that translated into shrieking, or one or more of your bearings/bushings is dry.
-Crandell
Thanks I’ll order a decoder. I was planing on installing one any way. any suggestions for a N scale Bachmann spectrum DCC ready NW J class?
My decoder of choice is the Digitrax DZ125. It’s good for motor and light control and can fit into tight spaces. It made for Z Scale applications but can be used in N and HO Scale equipment without a problem. I have them in a pair a Athearn SDP40F locos and they run fine.
