I purchased a Tsunami sound card last April. It was working great till I installed the shell on the loco. I think it shorted out against the frame or fly wheels. I have been contracting Tsunami customer service back and forth for the last 4 months now via email and all I get is the run around, asking me to try doing this or that. I heard they are suppose to honor the warranty even if it was something I did,( ie: short circuit). Has anyone else having this problem? Can anyone suggest another coarse of action other than this emailing back and forth. I hate to throw away $90.00 sound card. [:(]
What is so hard here? Send it back with proof of purchase and they will fix it. 4 months? They may charge you because it was your fault…but I am unaware of Soundtraxx’s return policy (I have had to pay for all my Soundtraxx decoder fixes).
The only time I needed service from Soundtraxx was when the decoders were under warranty. There is a ninety day warranty that is free in terms of service and parts. All I paid for was postage to them. They sent them back free of charge.
To my knoweledge, only TCS replaces decoders with no fault attributed.
I would expect that a repair for something I did that was improper would be a cost I should bear. If I drove a new car off the dealer’s lot and pranged it against the lamp post next down the street, I wouldn’t expect them to rush over to me and offer to fix it all for nothing. If the wheels fell off the car, that would be another matter.
I think you’re confusing TCS with SoundTraxx. As near as I know, only TCS has a “Goof Proof” warranty and will replace a decoder even if it was damaged through user abuse or miswiring. A sound decoder is a whole different ball game – if you destroyed it, you pay for the repair. I’ve dealt with practically every sound decoder manufacturer, and none of them offer free repair service if the damage was caused through user error. And they can tell immediately by just looking at their decoders that the damage was caused through user error.
Instead of exchanging endless e-mails, your best course of action at this point would be to box the decoder up and mail it back to SoundTraxx with a credit card number or some other form of payment for the repair, and be more careful the next time you install it to insure there are no bare wires touching anything.
If you check the SoundTraxx web site, I’m sure thay have their warranty terms spelled out in detail, along with instructions on how to return a damaged product.
I installed a Tsunami last year. I tested it every step, and when I had it all wired in, it would short out when it went into reverse. I don’t think I did anything to damage it. I swapped a few emails with them, and described all the error codes and such. Finally, they said to send it back, and they replaced it for free.
Have you sent it back to them? At this point, I would just ask them for a Return Authorization number. Use that phrase.
I have had great experiences with Soundtraxx. I have returned two of the 25+ I’ve bought for repair(always my fault). BTW, one little thing that helped me was to tape the bottom of the cap to keep it from grounding( even the larger caps I add sometimes).
Anyway, I would suggest you call them and follow their directions. I send an enclosed typed letter along with a copy of the receipt. I don’t think I’ve paid over $25+ plus postage.
Digitrax also repairs/replaces with no fault attributed, not lifetime, but for the duration of their one-year warranty on all their products (not just decoders):
Thanks for all the input and help. I called them on Friday (2-18) and the lady at customer service was very nice and helpful she said just to box it up and sent it back. I did send the decoder back. The issue I have is that in all the emails that where sent back and forth between me and the customer support person, he never once said, “ok, send it back.” He always wanted me to try reprogramimg it, then telling me to put my Zypher system in blaster mode and try to reprogram it. I am waiting to see how much the repairs are going to be. :o(
I also sent a sound board back due to it keeps shutting down and just a lot of static through the speakers.I hooked it up to my ESU51900 before installing it in the engine.Got it back yesterday after 3 weeks and still does the same thing.So sent it back again with a note please replace cause its still not fixed.
Unless I am mistaken you are testing a Tsunami decoder on a ESU (LocSound) decoder tester.
This tester has a 100 OHM speaker, I believe. The Tsunami’s require a 8 OHM speaker load.
The Tsunami will more than likely NOT work very well driving a 100 OHM speaker. Causing it to heat up and go into a thermo shut down, plus the static you hear from the speaker.
I would check the speaker on the tester to see just what the speaker is rated for, I will guess that is a 100 OHM speaker.
Using the 100 ohm speaker will cause the volume to be extremely low or maybe not get any sound, but it won;t overheat the amplifier. Using a 4 ohm speaker where an 8 ohm is specified, however…
The higher Ohm you have on a speaker, the more power (or amplifying) the speaker needs to get the membrane moving (making “sound”).
The reason some Mfg´s are using 100 Ohm speakers is that even though they need more amplifying, they can produce better sounds (less static).
If you install a 4 Ohm speaker in a 100 Ohm system, you get power rushes, wich can destroy both the speaker AND amplifier.
If you install a 100 Ohm speaker in a Tsunami, wich will need an 8 Ohm speaker, it will not make the membrane move much due to the higher resistance =lower sounds.
I thought that would be the case. I wouldn’t be surprised if it were done for free, depending if you have your receipt and it’s under a year old. But they really do try to keep the repair costs down even out of warranty. For example, instead of just throwing the decoder away and sending you another one, they will actually try to fix it. Richard
You can look at it two ways, one, a lower ohm rating is closer to a chort circuit, which means more current flows.
Or along the same lines, for a given voltage, the lower the resistance, the higher the current, following from Ohm’s Law. With amplifiers and speakers it’s actually reactance since it’s an AC wave form but the idea is the same. The lower the speaker rating, the more current flows through the amplifier (also generalizing - there are many types of amplifier circuits and they don’t all behave the same way). Up to a point this might actually be helpful - more speaker movement for the same voltage - volume. But lower than what the amp was designed for results in too much current flowing which results in overheating or failure.
