For those who are interested, or have been wondering about CVP Product’s Easy DCC system, I offer the following review.
First, a bit about myself. I’ve been in the hobby 25+ years, and up until now, have been DC only. I model in HO scale, and have somewhere between 60-75 locomotives. I had acquired a set of 4 Intermountain F units with sound, and wanted to be able to have more. I know the MR staff uses this system on their layout, so I got one for myself.
I ordered the system by email, included my credit card number. I ordered the Extended Starter System, and the SBZ7 to DBZ7 upgrade - since I needed the autoreverse for reverse loops. The subtotal was 499+a few bucks for UPS. I got an email the next business day, confirming the order and saying everything was in stock.
A couple days later I arrived home to a box on my doorstep. I opened it and found a packing slip, credit card receipt, several smaller boxes, some foam packing peanuts and considerable documentation. I unpacked all the boxes and checked the contents. Everything was accounted for and arrived in good order.
I followed the instructions for hooking everything up. Since my layout is still in the early construction phase, I only had a short length of track available for testing. I wired up the booster (I used the Autoreverse side for testing purposes), connected the command station, and the respective power supplies. I did not adjust the voltage switch for the booster’s power supply. Apparently it’s only good for 120 watts, using a lower voltage allows higher amperage. It was on the 15 volt setting, and for HO scale, I left it there.
The ZoneMaster Dual (DZB7) has a 4-page instruction booklet. Since my installation was fairly basic, all I needed to do was run wires from the track outputs to my track, connect the power supply, and the data bus cable from the command station. I did not adjust the trip c
