I know there has to be a quick fix for this, but I cannot find it. I was installing a decoder in a engine and got the two motor leads reversed so now the engine runs in reverse when its actually in forwards. What CV do you have to program to resolve the problem? Thanks!!
On many decoders adding “1” to the value in CV29 will reverse the engine. So if it reads as “34” and you change it to “35” that should reverse it. Not sure about NCE but give it a try and see.
Dan conveniently provided you a link to the D13SRJ manual above. (Should also work for the D13SR) Click on it. You’re answer should be there. You can also go to the NCE website and download any of the decoder manuals directly onto your computer.
Best bet is to read CV29 on the program track. If the value is an even number the decoder is set for normal direction of travel (NDOT) to be forward. Add 1 to make it an odd number and program CV29 to the odd number. The decoder will now run with NDOT in reverse.
If Cv29 is an odd number the decoder’s NDOT is set to run in reverse. Subtract 1 from the even number. Program the resulting even number to CV29. Now the decoder will run with its NDOT in the opposite direction.
This is an NMRA RP so the procedure will be the same for all NMRA compliant decoders.
