programing soundtrax minny steam decoder
canot get decoder to accept programing i use mrc dcc unit is not problem would appreciate any info do not have tec manual thank you
If what you are calling the mini is what Soundtraxx calls a micro, then the manuals are available at the following location: http://www.soundtraxx.com/manuals.php. I believe that what you would need are the Tsunami steam users guide and the Tsunami steam technical reference.
Manual for the decoder or the system? Either way they are available online…please use Google. Should take all of 5 seconds to find the info you are looking for…
David B
thanks for info,seams i need a programing booster to do this as my system does not put out enough power. thanks again everyone.
I’m not familiar with your MRC system, but as far as I know the only time you need the programming booster is if you are programming on a programming track. Why can’t you program the engine on the main? If you are concerned that you might program other engines, just remove them from the rails. There is a risk with this, of course, if you installed the decoder yourself and miswired something. Then the decoder could fry if you hit it with more current than what the program track has available. But programming on the main is an option if you want to take a chance.
(or does not the MRC system put out enough power to even program on the main?)
No…you dont need a page booster…
David B
