I have an MRC Synchro Sound (AD750) system I’m trying to play around with. I’m having difficulties programming it. I fooled with it about 2 hours last night, and got it to work one time. I don’t seem to be able to get it to take an address.
I have a Digitrax DB100 and DT200 throttle, the old “Big Boy” set.
Thanks cacole, but I have that sheet in the box. It’s a a 4 page, counting front and back cover, boooklet about 3x4in in size. Not much info there. [%-)]
When I power on the Digitrax, the MRC unit powers up with idle sound. But I can’t seem to access the AD750 to re-address it. I got it to to work one time, but when I tried to reassign the addy, I lost it again.
Someone brought one of those things to the club a couple of years ago and wanted to try it out. I fiddled around with it for about 30 minutes but couldn’t get it to do anything other than a horrible sounding horn and out-of-sync diesel rumble. The only address I could get it to work on was 3.
It seemed to be a little oversized and cumbersome to use as a paperweight, which is the only thing I would ever consider using it for. On-board sound decoders have made this thing technologically obsolete.
I got it to work one time on addy 14, when I programmed a loco to that address. I might have left it there, but that loco already has sound on board! [banghead] I tried it with a non sound loco, and couldn’t get it to work. I’ve tried addy’s 1-30 to get it to respond…nothing.
Oh well…I’m about to go to the train room and fool with it some more.
I don’t know…I fooled with it last night, and never got it working. One time, the idle sound stopped, then came back on with the bell. [%-)] Another time, the horn came on. [banghead]
Did ou notice where it says it must be programmed on a programming track? This seems to indicate to me that every time you want to run a different locomotive you must disconnect the sound system, move it to a location where it can be connected to your programming track, reprogram its address, and then move it back to the location where you want to use it.
No, but I noticed it said "It is best to do all your loco and Synchro Sound 750 programming on a separate programming track."
I just figured that is so you don’t reprogram your other locos. I’ve been programing on the main, both with and without a loco on the main. The one time it worked, there was a loco on the main, and it programmed to the addy I was putting in the loco. I tried that again, and it never responded.
Unfortunately, I bought the decoders and sound system several years ago, before there was much feedback on them. So far, the motor decoders seem work “OK”, but the sound sucks. I really don’t like the lack of programmable CV’s.
Too bad I have 7 more brand new MRC decoders. [banghead]
