I finally broke through the pink foam barrier on my layout and now have some color and texture to look at! Here’s a picture of what the area looked like before the color and some ballast were added:
I went back through this area and applied a second coat of plaster to fill in the holes on the plaster cloth visible in this picture. I also added a tunnel portal to disguise the dead end tracks. I still need to paint, weather and detail the Glacier Gravel Company building. I also painted the base foam a ‘earthy’ tan color that was a close match to Buff colored ballast. I sprinkled the buff ballast onto the tan paint while it was wet for a little contrast in color.
Here’s the results of my first attempt at ballasting my rails. I also applied a ‘stone grey’ wa***o the tunnel portal, adding some color and detail to the cut stone. Any comments or criticisms?
You put this together in less than 24 hours ? I only ask because on 7/3 you said you just bought it. I bought mine yesterday and am still staring at the box and all the pieces. My question is whether I want to paint the pieces first, before assembly.
I did receive one suggestion to go along the rails and clean off the ballast that stuck to the sides of the rails. After looking at the photos full sized, it was pretty obvious that needed to be done.
I laid a piece of foam down that was precut to fit the left-right dimension of the alcove and drew a line to represent the base of the wall. After I cut it out, I laid the cut piece on top of another piece of foam and traced the cut line. I then freehand drew another line to represent the top of the wall, recessed back from the base line that was cut. I then glued the top piece onto a wall of foam that is visible in the pictures, filled the void with newspaper and covered with plaster cloth. I brushed on a skim coat of hydrocal to fill in all the the holes in the plaster cloth.
I hope to make some rock molds this week and get them applied to the wall so I can put some color to that white behemoth.
I’ll think about the grass/weed idea…this is going to be a very busy gravel pit, so I’m not sure the weeds will have a chance to take over the rails. I’m going to visit a local rock quarry that has rail service this weekend to take photos of their rails to see how much detail I need to add to make it look more prototypical.
