Proper name for a double pole switch
What is the proper name for a double throw double pole non latching switch that returns to center off when released?
DPDT center-off momentary switch
Double pole Double throw momentary center off
If you want momentary in both directions it would be DPDT Momentary-Off-Momentary.
Mel
My Model Railroad
Bakersfield, California
In technical specs, like you would see in an electronic supplier catalog, it would be:
(ON)-OFF-(ON)
An ordinary DPDT center off toggle (not momentary) would be:
ON-OFF-ON
And a DPDT non-momentary toggle that is not center off (liek the reverse switch on a DC power pack) would be:
ON-ON
Thos designations just ferfer to the number of throws and momentary/not momentary, and center off/no center off and actually apply to any number of poles, so the DPDT part needs to be stated as well.
For example, the SPDT mometary buttons like the Atlas turnout controls are SPDT (ON)-OFF-(ON)
There are all kinds of technical terms that could make the description crazy.
If you just want to search the internet to find one, enter this into the search box:
“DPDT momentary center off”
That should find what you need.
-Kevin
Miniatronics is my favorite source for toggle switches. They sell three different styles of DPDT, referred to this way:
MINI TOGGLE SWITCH-DPDT
MINI TOGGLE SWITCH-CTR OFF-DPDT
MINI TOGGLE -CTR OFF-MOM SPRING -DPDT
I’ll take “Simple Answers” for “$200” please.
The Answer is: ‘The Proper name for a double pole switch.’
What is…
A CHERRY BRANCH ACROSS BOTH CHEEKS??
No, I’m sorry, the correct Jeopardy answer was ‘geomagnetic reversal’.
What is: “a wedding in Krakow of two pair of identical twins conducted by a demented pastor.”
Atlas turnout switches are momentary “on” not momentary “off”. In addition, they are always “off” while at any position until pressed into contact. So are momentary contact also.
Peco operate with the same effect, always “off”, but are passing contact so always switch “on” once per motion of the switch. Atlas have one advantage in that you can pre select the direction of turnout throw and then some time later activate the turnout motor, very handy.
What is: " a swinging singles party in Warsaw attended only by sets of twins?"
I could go on …
Wish you would… [;)]
Bierut and Osobka-Morowski for Sikorsky and Raczkiewicz? Center was certainly off…
Yeah, but how does the piano sound?
Ooops. Sorry. Wrong forum.
This thread derailed.
I hope “ndbprr” got his answer and we were somewhat helpful.
-Kevin
