What is the proper term for this panel indicated below with numbers 274?
I have some Stewart F3s/F7s where this is blank, what is good solution for getting decals or dry-transfer numbers for these?
Thanks!
Thanks!
Everybody called them number boards.
Microscale makes number decals you can use. Other companies also, I am sure.
Ed
Except when they’re used as train indicators. UP & SP (and maybe other “Harriman Roads”) used them to post the train number. So they might say “12” for train number 12, “2-4” for second section of train number four or “X1234” (X followed by the locomotive number) for Extra (unscheduled train) number 1234.
Here UP locomotive 930 leads train 108
Big Boy 4003 heads up an extra
On modern engines where they are at roof level they are commonly called bugboards. You can get 3 different types of decals.
Black numbers on white background
White numbers on black background
Clear number’s on black background that can be backlit
I have never once heard that before this post.
If you’re looking for decals to fix up a model, they will 100% be called “Numberboards” in the set description(s).
Except when a company like Champ makes them; I remember seeing ‘bugboard’ sets in both HO and O scale.
I suspect this may be a ‘regional’ thing. I too never heard them called anything but numberboards.
I remember reading stories in Trains magazine during the 1950s, where a crew member (fireman or head end brakeman) had to change the “bugboard numbers” at the end of the run. Soon, when a tender is mentioned, the thought will go automatically to a piece of boneless chicken.
