I noticed Walthers sells two different types of geared axles for the Proto 2000 and 1000 locos. One is for “Early Proto 2000 (R) E6/7/8/9” and the other is for “Early PROTO 2000(R) BL, FA, GP7/9/18/20/30/60 & PROTO 1000™ F3,RS2,RSC2”.
Will someone explain what’s different about the two? I always thought those cracked axles got replaced with one type, your standard Athearn geared axle. Which leads into my next question:
I replaced the cracked geared axles on a Proto 2000 FA1/FB1 set.
I never operated them on parallel tracks before the change, but they run at different speeds at the same voltage (one power pack running both simultaneous). Can someone explain this?
I have a set of Walthers Mainline FA’s that ran at the same speed until I installed American Limited diaphrams. Maybe this is a problem with Alco cab unit models.
Probably not. Most likely just a weird coincedence.
One probably has a different gear ratio than the other. A lot of older Athearn, some Life-Like and others had a 12 to 1 gear ratio which would make it faster than a now gear ratio standard of 14 to 1, running at the same voltage/rpm. They did that because most Modelers wanted better slower speed control/ better pulling power verses fast.
Frank is right. I believe the E6/7/8/9 gears had fewer teeth (12 I think but I could be wrong). EDIT: Mister Mikado has done the tooth count and there are 11 teeth in the E6/7/8/9 gears. The number of teeth really doesn’t matter, but gears with the wrong number of teeth won’t run properly.
The exact specifics escape me but I can look it up. In short, the Life-Like manufactured E- 6, 7, 8s had a separate journal box on the truck side frame and the axle had a small nub that engaged this journal box. That nub sticking out will not fit into the Geep sideframe.
They became troublesome and when Walthers re-tooled the line after they purchased Life-Like this setup was eliminated.
Dave, I just inspected some of my Protos. My P2K E8 axles have 11 tooth gears and slightly larger wheels. Sounds odd but I checked 3 times by marking a block. My Proto 1000 Erie-built has a different kind of gear–it’s offset toward one end, 12 teeth. My FA/FB1 set has the familiar 12 tooth animal and all 8 match, so I still don’t know why one runs faster.
Sometimes there isn’t an obvious reason. When I ran these Proto engines, or many other manufacturers for that matter, back when my layout was DC it was not unusual to have some engines running faster. I would put these in the lead so there was a slight tug on the drawbar when running multiple-units.
With DCC decoders, of course, you can fine-tune (speed-match) the engines to follow the same, or close, speed response curve.
Some locomotives, Kato and Atlas come to mind, seemed to be built to closer tolerances and the speeds were more constant between locomotives.
How much of a difference are you talking about? There’s no harm in rinning engines that are slightly off in the speed range.
You just said in Your reply…(wheel size) the one with the slightly larger wheels should run faster. That also has to do with the gear ratio. Why do You think a Steam engine used for passenger service with larger wheels will out run a steam engine used for freight service. Your Auto is the same way. Two exactly the same autos, same engine, everything the same, but one has larger diameter tires…that one will have a higher top end speed then the other at the same RPM. In the steam Locomotives, they did not have to pull as much weight as the freight , they wanted them to be faster so they had larger drivers, but could not pull as much as an engine for freight with the smaller drivers. Look at the size of the drivers on a Pacific verses a Mikado.
thanks for the info. I’m tuning up a number of my older run 4-axle P2K diesels for DCC operation, so I definitely want to have a batch of replacement axles on hand. I’ve replaced axles on two units, so far. Although most of my P2K’s are currently sitting inside of their boxes, l learned from experience that axle “dry-out” can still occur in storage!
Interestingly, although they’re 15 years of age (and older), none of my P2K E-units have had the axle issues yet…but I still plan on being prepared.
My first LL Proto 2000 purchase was a NOS E6A with dummy B. There was one or more cracked gears, the telltale (besiders operating observation) being much too easy to twist the wheels. As noted above, the Athearn gears were the wrong number of teeth. I even tried replacing all 6 axles with the Athearns and, while it may just change the ratio and run ok if lucky, mine did not run or sound right. The Walthers fellow told me the meshing was likely not quite ok. If you have trouble finding the right geared replacment wheelsets, one solution (if you are lucky) is Walthers may have (ask the Tech guys, not sales) a replacement truck from which to glean the wheelsets. That solved my problem when they did not have the E6 wheelsets stocked a few years ago.
Plus, I encourage taking better notes than I have. If you disassemble things (as I do when converting DC items to DCC), document the teeth count, note the wheel diameter and which axle gears (if not all) have been replaced. My batting average, if I checked, is probably about that of a pitcher.
I’m bidding on a Proto 2000 ACL GP9 (Purple/Silver) on evilbay, Will I have to worry about the gears cracking? How long will the locomotive last before the gears crack?
A suggestion. Expect at least some of the gears to be cracked. Or take the approach that they will soon crack and just replace them. So I’d order the Atheran 60024 gears (works on a LL GP) and get them on the way.
It’s easy to pop off the bottom truck cover and lift out each wheelset. Twist the wheels with your fingers to remove the gears from the 1/2 axles. (Any cracked ones will be easiest.) Add the new gears (reasonably centered) and use your NMRA gauge to adjust the flanges to the exact center of the gauge slots. That ensures no problems tracking and provides a small electrical gap in the middle of the two metal 1/2 axles.
I’ve acquired a number of P2K and P1K DC locos to convert to DCC/sound so I had to get into them. While in there, I disassembled the trucks, cleaned everything of old lube and lubed the gears and motor bearing. You should consider that, as the factory grease has a tendency to set up into a sticky mess, plus eventually the motor bearings deserve a drop of oil. You will have to do it eventually anyway. It’s not that hard once you get the shell off. Ask questions as needed.
On the issue of the P2K Geared Driver Assembly (Cracked axle gears)…Just prior to Life-Like Trains in Balt. MD. selling-out their entire inventory to Walther’s - I recall Life-Like mailing-out these axles by the thousands! Unscrupulous people, got huge amount’s of new axles, FREE, just stating they had X am’t of the LL P2K loco’s or similar stories. IIRC, this was around 2002? I saw hundred’s of the new P2K axles at various train shows for sale by dealer’s who typically stated “You can’t get these anymore” (various prices). Life-Like finally “got wise” & asked how many loco’s you actually owned, and how many had the problem. I truthfully told them “twenty” They mailed the new axles (Gear Driver Assembly), to me, NO charge! YAY! However…on close inspection to all the packaged new axles, almost 95% were cracked! The problem was the metal half-axles, when inserted in to the plastic axle, cracked the plastic, because the metal half-axles, were a bit too large, for the axles, or the axles holes too small… We’re talking thousand’s of an inch…but that’s why there was always an issue with these. When Walther’s took over, & the dust settled, they would send only a few new ones out, and eventually, you had to purchase them. That was fine too! Go with the Athearn #60024’s for the four-axle units. (FA’s BL’s GP7s/9’s/18’s/20’s etc.), NOT the “E” units. Make certain when you drop the new geared ass’y into the metal frames, that the square bronze nut piece is aligned with the frame. As stated, use an NMRA wheel set gauge for the correct width, & if you din’t have one, just be absolutely certain that the metal half-axles don’t touch! If you see arcing when running - they are shorting out! Cheers! AL
