Proto 2000 SD45 body removal?
How in the heck do you get the body off of these things? I’ve tried for a hour now and it won’t budge. Does the number board lights need to be rewired like the GP38-2’s as well?
All the P2K locos I have have 4 attachment points. The first 2 are easy, The coupler draft boxes. Remove the screw that holds them in and pu***hem out of the front and rear. The next place is usually 2 additional screws located under the loco near the fuel tank either front or rear. Not the screws that go through the tank they hold the weight and/or engine to the frame. After the screws are removed I have to take a small flat screwdriver and gently pry up a little berween the frame and body. Be careful and slow you should get the loco apart no problem.
YAHOOOOOO!!! Finally I got those suckers off.
