Proto 2000 side rod repair
Does anyone know hoe to remove the bolt that holds the side rods in place on the third driver of a Proto 2000 0-8-0 switcher? I have the part to replace, but I cannot figure out how to remove the one bolt.
I don’t know that loco, although I have its smaller brother, the 0-6-0. I suspect you’ll need a driver set of the kind that Micro Mark sells. I can’t help with imperial vs. metric…sorry, I have no idea. But Micro Mark, google that name, sells both kinds of miniature drivers.
I will try to post a picture as soon as it gets approved and i probably should have mentioned this in the earlier post, but the “bolt” on that drive is actually molded into the valve gear rod. And on the inside face of the driver, there is no screw head either. I simply can’t figure out how it is attached.
From your description, I would guess that you should NOT try to remove that rivet unless that piece is the one that is broken. The ‘side rod’ would normally be only the main rod that interconnects all 4 wheels, not the push rod connected to the 3rd wheel and the cylinder slide.
If the part which you wish to remove is the drive rod (connected to all four drivers on each side of the loco), that is indeed a bolt holding the rod in place on each wheel. (Technically, it’s actually a hex-headed screw, as it’s not used with a nut.) [:-^]
You can make an open-end wrench from sheet brass fairly easily, and a box wrench with only a little more effort, but I used a small pair of smooth-jawed pliers - grasp the bolt head with the end of the jaws (not the side) and gently twist to loosen. When you re-assemble the loco, don’t overtighten itt, or you’ll strip the threads.
While this link concerns a gear repair for the same loco, I had to check my post to make sure I was remembering correctly. [swg]
http://cs.trains.com/mrr/f/88/t/226404.aspx
Strezzy,
If you would like a free Micro-Mark catalog and E-mail, you could always use it as a reference, even if you never buy from them:
https://www.micromark.com/ssl/catalogrequest.aspx
Frank
OK - I finally have the picture from the gallery. There is no bolt per se’ and the exploded diagram in the box shows the part connected to the value gear is the same as the pin that hold all the rods in place. So what you are saying is the I would need to unscrew that entire part (which I tried to loosen, but it is set pretty firmly) by unscrewing from it the driver?
I frequent the MicroMark site so I am good what navigating there. Thank you!
As you can see below, the “bolt” is molded into the part and there is not much of an edge to grip with a wrench of any kind.
Picture is the gallery for now.
http://cs.trains.com/mrr/m/mrr-layouts/2289392.aspx
I’d guess that the fastening is still a hex-headed screw. To turn it, use the eccentric as a wrench. Once the threads are free of the thread in the driver, you should be able to press the eccentric towards the driver, freeing the screw head.
After you’ve made the necessary repair, re-assemble things in reverse order, threading the screw into place until you can no longer grip it. Lift the eccentric and eccentric rod and align the hex-opening with the head of the screw, then use that to re-tighten the screw.
The exccentric is the screw. Grab it gently with a pair of needle nose and turn left. Lefty loosy righty tighty. There may be shims under the shoulder of the threaded screw part that sets the exccentrics angle.
Pete
OK - tried last night and that thing is ROCK SOLID! not moving in the slightest. I’m afraid it will bend or break and that would be bad.
I think I should just send it back to Walthers and have them take care of it.
[:|]Solution…
New loco. They sent me a new one. Probably using the other as a parts source.
Or they couldn’t loosen the bolt either!
Glad to hear that you got the problem resolved. [tup]
