I want to run passenger trains on my 4x8 ho layout. I read an article in a model rainlroader last year about pike size passenger trains and thought this was a great idea. However I am unsure how the “newer” longer passenger cars will run. Today’s cars are longer than they used to be.
Your best bet would to run either Athearn or Con Cor cars. The models you mention are prototypically scaled in length of 80-85 feet in length. Athearns and Con Cors shorties are 72 scale feet in length. The longer cars will require a minimum radius of 30 inches, the shorter cars will work on radius’s of 18-24 inches.
Ch
Good suggestion. I use the 72’ cars on 24" curves and they work fine.
Thank’s for the advice. perhaps I should also post this question in the protoype forum.
The Con-Cor smooth side passenger cars are shorties; the Con-Cor fluted side cars are ful length. Don’t ignore the new 60 foot standard passenger cars from Walthers. There were actual prototypes for cars this long – unlike the 60 foot streamlined cars from Mantua, Model Power and some others.
Dave Nelson
For a layout that small. it might be a good idea just to run an RDC. The Santa Fe had a couple of RDC-1’s (all coach). One of them was rebuilt into something that looked like an RDC-2 (baggage-coach). A doodlebug is another option. In the last decade of real passenger service, the Santa Fe ran a train using a dieselized doodlebug (actually two) along with a streamlined observation coach or less frequently, a straight coach. Also active well into the 1960’s were mixed trains. Short, mineral brown combines along with some freight cars and a GP7 or two provided service totally ignored by our glorious government today. Instead we have foreign oil, oil wars, and terrorism on our shores. There IS a connection.
Stephanie Stout
I run 2 80’ vista dome and observation Walter’s cars and some Bachmann heavywteights on a 22" radius curves pulled by a BLI EMD 7A and have no problems. It really runs smoothe.
