The discussion on TT length prompted me to lok closely through a booklet on steam locos I have, now it says on each of the locos spec sheets what type of curve they were designed for (eg 18 degree, 30’ curve for a J3a Hudson).
I am led to assume that this means a the loco was designed to fit through curved sections that made up roughly 18 degree arcs. What would that 30’ be used to describe?
It’s easier to do this than to get out the furlong compass (generally sold at places that distribute Avogadro tweezers and unobtainium).
As that page shows, the eighteen-degree curve mentioned is about a 44" HO radius. Physics being unscalable, we can get away with a lot more. In fact, the real J3 would have to go pretty slowly on a curve that sharp.
Eighteen and a half degrees equates to a (prototypical) three hundred and nine foot radius curve - and even with superelevation that is likely to be rule-booked a slow order curve. That computes to an HO Scale radius of forty two and eleven sixteens of an inch.
Thanks guys [:)]. Never could quite grasp measurements when they started using minutes and seconds… especially since the symbols are the same as those used for feet or inches.
