Well, i’ve begun work on my more realistic, super-detailed catenary. THIS is what i wanted to do for that contest, but could not.
I basically only have one pole mostly done, as it is TEDIOUS adding some of the details, mainly the grab iron ladders. The transmission arms are on, as are the insulators. All this pole will need is possibly a signal line, and it will need various braces, but these parts can wait until the overall Catenary structure is built to be installed. On Friday, i hope to begin a few more poles, so that i can roughly complete about three or four catenary bridges.
I basically started with a three foot piece of 5/32 brass H-column stock, and a pair of scale 13 foot long brass “A1” angles (smallest angles you can get from special shapes, i think). I went ahead and marked their location on the pole, which is a little lower in the case of the catenary along Perth Amboy, NJ, which is where i draw my inspiration from. As such, i am only adding one set of arms per pole, rather than two like on the Northeast Corridor. After carefully lining them up, i soldered the two angles back -to- back on the pole, and then pulled the tips together and soldered them as well.
I then used a dremel drill press and a small high-speed cutter to make little dimples in the side of the pole for the support wires that hold each arm up. I soldered a length of wire into the dimple, and used flush cutters to cut the wire just as it reaches the tip of the transmission arms. I then soldered this loose end of the wires to the tips. I then put the pole into a grabber-stand (not sure what they are really called, roll with it! :roll: ), and put a VERY small right angle bend at the end of the wir
