PSA Adhesive
I recently ordered a bottle of the new PSA (Pressure Sensitive Adhesive) Adhesive that I saw recently advertised. I thought it looked like it would be good for attaching trim to structures etc. I’m pretty messy when it comes to glue so thought this might be worth trying. . Anyone have any experience using it?
Mike B.
Hello I use psa at work but it’s not a liquid it comes in a roll 18’’ x 200’. We use it on gasket we make. I did bring some cut offs home and used it for some signs. I cut the sings out of a old MRR and psa them to some .001’’ tin foil so the look like metal sings. I am working on a kit and all the trim is peel and stick and it coming off. So it will get a spot of glue. It is recommend in the instructions also. Give it a try on some test parts. Hope this helps Frank
