For those who don’t frequent the Trains Magazine forum, where I mentioned this:
It came to my attention this morning (via RyPN) that there is video of the women pulling a Niagara. It’s toward the end of this interesting presentation:
Note how carefully this includes the different types of roilling-element bearings, including balls, with a good cut of SKF-style barrel thrust rollers showing their off-axis prowess, so this isn’t a publicity shot for Timken as I’d have otherwise suspected.
Note the amusing claim that passenger trains ride much more smoothly when equipped with antifriction bearings… this is of a piece with one of my college roommates who was talking about ‘riding the rods’ and said “I don’t see what the point of that “Hydra-Cushion” was… it didn’t seem to ride any softer than regular boxcars did.” (This was the same roommate who complained to me that he got his car with a Ford-O-Matic transmission up over 80mph and couldn’t get it to go into third gear – I told him he’d be able to found a new religion if he did, because a Ford-O-Matic only has two speeds…)
I did notice those spiffy off-axis barrel spinners, and I think that might be the first time I have seen anything iike them. I had to slap my forehead because they are so obvious…now.
Kind of weird to think that Hydra-Cushion is more than old enough to be a legitimate topic for Classic Trains…
One of the things I remember from reading late 60’s and early 70’s issues of Trains was that the end cushion versions did some not so wonderful things for slack action of a long train, though the sliding center-sill cars were much less of a problem.
I don’t think the type of anti-friction bearings had much to do with passenger car ride, but anything with a friction coefficient much higher than a plain RR journal bearing would be a pain to keep cool. Hotboxes got hot for a reason.
I was under the perhaps wrong impression that the Ford-O-Matic was a three speed automatic, but the D2 position would start in second. The Ford C-4 “2” position was selecting 2nd gear as opposed to limiting upshifts to 2nd. In both cases, the 2nd gear start was to help with low traction conditions.
The three-speed was “Cruise-O-Matic” – it is what I had in the '62 Thunderbird. The '63 case had a reinforcing rib to correct its cracking in the location mine did…
Remember that this is the ‘second’ Ford-O-Matic, the one from '59 to '63. Think of it at Ford’s answer to the original Powerglide.
The pre-'59 had two speeds plus a sort of granny ‘low’ that you were only supposed to engage under extreme conditions.
