I need some help from the electronics experts on this. Both batteries in the voltmeters on my PW ZWs are apparently shot since they will not hold a charge for more than a couple of hours. The batteries are the originals from around yr 2000.
The instruction sheet says the battery replacement is a NiCad 9volt, 160Mah rating. In looking around on the web, I noticed that most rechargeable batteries are now of the NiMh variety. Most are either rated lower than 160Mah or higher. Ditto for the NiCad rating.
So, the question is: does the voltmeter have to stay with a NiCad? Can the Mah rating be higher without causing failure or incorrect readings?
Thanks,
Bill
