QSI Automatic Headlight and Reverse Light Configuration, CV 55.70.1 & 55.73.1
OK, I’ll admit it right off. I do NOT want to learn how to manage my own way through the 400+ pages of the QSI DCC Ref Manual. [sigh]
I just want the lights on my Atlas C420s to go On when in forward and Dim when in reverse. That’s all, nothing about programming a trip to the moon or anything else exotic, which I’m sure QSI does wonderfully for those few who can appreciate all the bells, whistles, dilithium-flux-capacitor management, etc.
I also haven’t a clue about getting anywhere past the first 2 digits for the wacky long CVs that QSI uses once I have the suitable string. Can someone also explain how to enter whatever string is needed? I vaguely understand about the existence of some warehouse accessed through CV 49, but after reading through that several times, I’m more confused than when I started, when I thought I could just change a couple of numbers, like in all those other less Olympian decoders.
My DCC system is NCE.
Mike:
I use the prodigy advance,but I think this should work for your’s,too,as long as Nce can handle decimal values for cv’s.
This assumes that cv 55.70.0 is already set to 1 (which is the default setting)
For the headlight:
Set cv49 to 70. or 01000110 (if binary)
Set cv50 to 1. or 00000001
set cv55 to 86. or 01010110
This should give you a front headlight that is bright when moving forward,and dim when reversed or stopped. If you want the light off when stopped,set cv 55 to 18 (00010010).
What do you want your rear light to do when (A)going forward -(B)stopped from forward- (C)moving in reverse -(D) stopped from reverse?
I agree - their explanations could be clearer. All that warehouse stuff instead of saying "before setting this value in cv55,first set cv 49 to 70,and cv 50 to 1…
Mike
Mike,
Hey, thanks! that’s helpful, as at least I know where to put numbers to make this work. I hate to sound like I’m whining, but QSI brings that out in me (I’ve managed to get over whining about Digitrax…mostly[:(])
What I want for the reverse lights is for anything in reverse to be dim or completely out. I understand brightness is adjustable, but would rather not touch anything beyond the simple stuff with QSI at first (in the likely vain hope that I’ll eventually figure it out.)
One more thing,Mike;
'Not sure about the programming track,but if you do this on the main,and cv 62 is set to 1,the speaker will read back what your doing.“CV (x) = (y)” etc. Also,if you want to know what value a cv curently has,set cv 64 to the # of the cv you want to know about.For instance,if you want to know what value is in cv3(Acceleration),set cv 64 to 3. Engine will say "CV3 = whatever value it currently has. To do this for the headligtht cv set cv 49 to 70,set cv 50 to 1,then set cv 64 to 55. Engine should say "cv 55.70.1 = 86 or whatever it’s currently programmed for…
For your rear light:
First figure out what you want your REAR light to do by adding the numbers from below.
moving forward: off = 0 dim =1 bright =2 (Choose one)
stopped from forward: off = 0 dim =4 bright =8 "
moving in reverse off = 0 dim =16 bright = 32 "
stopped from reverse off = 0 dim =64 bright =128 "
Add up the values that you chose.
Set cv 49 to 73
Set cv 50 to 1
Set cv 55 to the number you came up with from the four running conditions.
"Hope I haven’t muddied the waters,
Mike
Mike,
Great, very useful. Thanks! I think I can mangle my way through. I’ve already shut down things for the evening, but should have a chance to give it a try tomorrow.
Mike:
Now you know why JMRI is so popular.
Joe
Get JMRI or the QSI programmer. It makes programming decoders as intuitive as browsing these forums. David B
Joe,
Yeah, I haven’t made the leap to Decoder Pro yet. If I was all-Tsunami, I wouldn’t even worry about that, but things like this do make me think you need some crystal ball or savant medium to intercede with the Gods of DCC.[{][}:)][}]
The answer is JMRI. For you, JMRI. for anyone with a DCC system, the answer is JMRI. When it comes to choosing a DCC system, the top consideration is JMRI. Whenever a post comes up like this, the answer is always JMRI. Seriously, spend the money for your USB to serial connector and down load the free JMRI and thank us later. The learning curve is quick and it covers every decoder ever produced. …or do you enjoy the attention? David B
Mike,
Thanks for your help. It broke the logjam some on figuring out QSI. I’m digging into other things now I wanted to fiddle with, so your assistance has been a very welcome.
