QSI decoders giving a constant non-stop beeping
I find that my QSI decoder equipped Proto 2000 GP7 diesels don’t function properly when I startup my Digitrax Super Chief system (DCS100 + DT400), unless I completely shut down the decoders by pressing 9+9 three times and then when I start up Digitrax activating the diesels by pressing 6+6.
If I close the system down without using 9+9 to shut down the decoders, when I start Digitrax up the GP7 decoders keep giving a beep about every second non-stop.
However, if the system cuts out because of a short and I have to close the sytem down and start it again, the GP7s work OK and don’t produce the constant beeping.
Anybody else had this happen? Am I supposed to shut down the decoders with 9+9 everytime I finish?
Cheers, Malcolm
No, that’s not normal. Shutting the down is nice, but you shouldn’t HAVE to do it. I don’t have on of the P2K’s but I do have 2 BLI’s and an Atlas, and without shutting them down, when I power back up with my Zephyr they don’t make odd noises. I don’t recall seeing ‘beep codes’ in the full QSI manual (go to http://www.qsindustries.com to get it - ALL infomation, not the subset you get int he loco manuals), but I could be wrong. You might also want to go to Yahoo and check out the QSI Group for more help. Pat Quinn himself participates.
Thanks, Randy,
I’ll follow up the leads you gave.
Malcolm
