quality
I have a question. should i build a simple layout ( a loop with some industrieal switching and an interchange. ) on my existing benchwork ( a heavy, wobbly, 4x8 ) or should I build somthing nicer and more complex but step-by-step. I would also build new benchwork. a simple layout would use E-Z track and be done in one weekend. any input is appriciated.
Alex the Rock Island kid[:)][:D][8D][:I][:p][;)][:o)][8)][^][?]
I’m gonna build 2 or 3 main lines with some industries in the middle and maybe a small frieght yard. I think it would be cool to go with a double loop with some switching and an interchange if I were you.
but should I build 2 layouts one practice and one permenant or should I start right off with a nice but simple layout that is expndable
I wouldn’t suggest building two layouts. This will simply divide your time and your interests. Instead of a separate test layout, why not simply use your 4X8 sheet and tack your track down in the various configurations you are considering. Then just hook up a power pack and run a few trains. This should tell you which configuration gives you the look and feel you are after. When you decide, start laying down the track more permanently.
As for new bench work, that depends on what you are trying to accomplish. If you are trying to save weight to make it portable or have more flexibility in cutting out sections to create elevations or depression, then it could definitely be worth while to create all new bench work. If not, then what you have already will do more than likely.
As for expansion, you can accompli***hat with pretty much any layout. It’s just a matter of adding on to the existing bench work and adding a couple more turnouts. Virtually any layout can be expanded.
Always keep in mind that anything you create you can always change later. The only constant is change in railroading.
Good luck with it.
Warren
I would recommend putting some time and effort into building stable, sturdy benchwork now, rather than having it plague every other step of construction–bad benchwork will cause problems with tracklaying, scenery and operation, and will then be more work to fix later. If you can’t shore up the 4x8 startt with a good strong foundation and go from there.
One thing I am doing (which you might try) is to build a layout in stages. I’ve started out with a shelf layout, 6x1.5 feet, and over time will add more and more modular sections to the starting base until I run out of room or money. That way I can have a completed section that I can operate on in short order but still have room to build and grow.
Train Boy – we have a member in our local club in SE Arizona who was born and raised in Rock Island, Illinois, and he models nothing else.
Well, as they say, the Rock Island line is a mighty fine road…
Trainboy,
Where’s the room plan we discussed? I have designed a layout for you that I think may work.
waiting for you to mail your plan…
a.k.a dhuff
I mailed it Monday.
my dad said that he is going to get a 4x8 sheet of plywood and some 2x4’s to build some sawhorses and lay the plywood over it since i’ll probably be moving out in a year or 2. i plan on having 2 loops that can hook up with one another. then have a small yard with some industries in the middle. also off of one of the sides of the main loop i’m going to put some extensions so that maybe in a few months i can add onto the layout if i want.
