Question about BLUELINE SD40-2 sound.
Can the sound be turned down or up on DC without using the DC MASTER ANALOG CONTROL MODULE ? Meaning is there a knob on this thing that lets you control sound volume.
Thanks
Mike
To my knowledge, there is a volume control knob under the dynamic brake blister. Pop that off and you should be good to go. If that doesn’t work, the instructions that came with the unit should tell you how to do it. I hope this helps, Michael
