Question about MR DCC article
I am changing a 35 year old brass engine to DCC. Two question. I am trying to change the motor from the Open Frame to a Can motor. I have tried to reach NWSL as I do not have a clue of which one I need but I have been unable to contact them. Any other suppliers you guys might know?
I am going to install Motor control only with no lights. In the DCC Articile on Pg 78 Jan 2011 MR. I understand except for two things.
  1. Why is he using TWO decoders?
  2. With my install do I just connect the four wires shown ? The wire he is talking about that runs to the tender. Is that for the other decoder?
Thanks in Advance
Harold
Harold,
The reason he was installing two decoders was to sepeate the wiring. The motor decoder is in the engine, and the sound decoder is in the tender with the speaker. Basically, that picture in Fig 1 is all you really need for a quick & dirty install. The problem with this kind of install is that the decoder is getting power from the RH drivers(3) and returning power via the LH tender wheels(4). Adding pickup shoes(like Tomar) would help with electrical pickup(especially with sound engines). In your case the existing electrical pickup may be OK.
Make sure that both motor brushes are NOT making any contact with the frame of the engine. Use a multi-meter and check it out. You do not want to let the ‘magic smoke’ out of that decoder!
Jim
Any idea on another source for the motor?
Get yourself a dial or digital caliper and spec out your present motor gear arrangement.
Go to the NWSL site and spec out the motors. Specs are there. The only possible issue will be for the older motor shaft diameter and the replacement motor shaft diameter.
I did that over ten years ago and found what I wanted for some motor/gear upgrades from NWSL
You just have to do some homework.
There is also plenty of gear info.
There are also some good motor replacements on ebay as one motor seller I have bought from also sells on ebay. I believe his company name is Micro Loco Motion. He did a custom gear motor for me for a 4-2-4 loco.
I wish I could. This is my first attempt at anything like this. That is why I am looking for a supplier that can go more by Make & Model. The engine looks exactly like the one in the article.
I think you should be a little more patient and keep trying to contact NWSL. I think they’re a small operation, and with the holidays and all they might just be taking some time off. I had some questions regarding gears for a Roundhouse HOn3 mudhen, and they were very helpful.
Plus, if you think you are capable of doing the remotoring, then I think you should be capable of making some rudimentary measurements of the existing motor. NWSL has an on-line catalog that gives the different available motor sizes and configurations, so you could do some initial research before you contact them.
Existing motor was a Open Frame. That is why I want to replace it.
NWSL will respond to emails. It is a small company and this is also show season, but I’m sure he’ll get back to you.
An alternative might be http://www.alliancelink.com/alp/ They produce the “Helix Humper” series of motors and drop-in replacement drives. Click on: “Photos Of Products & Instruction Sheets”
There seems to be an assumption in these forums that:
  • open frame motor = bad
  • can motor = great
While those statements may be true, they are from universally true. First off, in a permanent magnet motor, the strength of the magnetic field at the armature has a lot to do with the efficiency of the motor. The stronger the magnetic field, the more efficient (using less current for the same torque) the motor can be. The stronger the field, and the more of a point source for the magnetic field through the armature, the greater the cogging action of the motor at low speeds. Cogging is why 2 and 4 pole motors are not used. With 2 or 4 poles, it is too easy for the magnetic forces to balance, and the motor lock up.
Another point is that shaft diameter for motors has decreased over the years. This means swapping out a new can motor for an old open frame usually means bushing the shaft of the can motor or replacing the gear box. The smaller shaft and lighter duty bearings of the new motors also means the worm should not be placed directly on the motor shaft. Universals are highly recommended for the small shaft diameter motors, even to the flywheel, to reduce the load on the motor bearings.
Open frame motor: The magnet is in a block, usually at one end of the motor. Or, it can be at the top or bottom of a U off to the side of the motor. The magnetic force is transmitted to the armature (the iron with the copper windings) by the motor frame, which is usually made of steel. Pros/cons of open frame motors:
  • the magnetic path is long and relatively narrow (like using small wire). It is more difficult to get a strong magnetic field at the armature. Rare earth and ceramic magnets were not a
Try a helix humper fron Robs trains in Alliance Ohio.1-888-313-4048 Tues thru Sat noon til 8, they are made to your specs if need be I’ve used them for years for Atheran locos,good luck,Jim.
