Question for HO Unitrack users – R876 turnout
Hi,
I am trying to redesign my layout using HO unitrack. I want to connect two loops so I can go from the inner loop to the outer loop and vice versa. The loops are 60mm apart (R550 and R610 curves).
I remember using the R550 turnouts back to back but found that two six axle locos coupled together tended to derail on the s-curve. Can I use Two R867 turnouts (2-860) back to back to get a distance between parallel tracks of 60mm. Will this be a gentle enough S-curve to stop two six axle locos derailing?
Thanks
Paul
