Just recently purchased an old layout sitting around for 10+years that has an old MRC 2000 dcc system. I have noticed today that the output fluctuates between 5v an 22.3v’s. When I have checked this before it has always been around 12.8v’s. Is this normal or has the system started to go south? (it is set on HO/N scale).
It is being driven by the AC side of a standard power pack.
Make sure Throttle 1, Set 1, Group A is not being adjusted and is set to stop - this one uses zero stretching to run a non-decoder DC loco, and as such alters the waveform of the DCC signal and will appear as a voltage change to s standard meter.
Also check your power distribution. If you’re depending on rail joiners, that could cause problems with voltage fluctuation around the layout. A good bus-and-feeder distrubution system is necessary.
Thanks, actually the loco is one being run on throttle #1, set 1, group A. I will check this out for sure as I never noticed it with any of the other loco’s.
