I am using Kadee magnetic uncouplers at different locations on my layout, these are the ones that go underneath the track. They work great with one exception, albiet a biggie. When my train goes over these uncouplers, and i dont mean at a creeping speed, some cars want to come uncoupled. Seems that the reason is that as the train goes along at times there is a little slack that quickly occassionaly occurs as the engine pulls the cars, and if this happens as couplers cross over these uncouplers, the cars seperate. Is there a way to rectify this? Obviously I want to use the uncouplers and they work well when Im dropping cars off at a siding, but I dont want them doing this with a train at speed per say, lol. Will this possibly go away once I ballast?
I piut drag on my cabooses by using Kadee caboose trucks with the electrical pickup. These seem to add just enough drag to stop most unwanted uncouplings.
I would love to hear a better solution if anyone knows of one.
I have issues with strong magnets actually causing slack, although usually when just spotting a car or two on a siding. This became a problem when I upgraded to metal wheels and metal axles. The magnets pull the uncoupled cars back to the magnet because those nice, smooth, low-friction wheelsets offer little resistance.
I planted a couple of tufts of field grass between the ties on the siding, which stopped the frre-rolling cars and restored smooth uncoupling.
B: I recall an article where the permanent magnet uncoupler was mounted on a hinged block under the roadbed. When you wanted to have the uncoupler for use you would pull a string or wire and the hinge would allow the magnet to lift to the proper under-track position for use.
Normally the uncoupler would swing free and not be in proximity of the track roadbed.
I suppose you could use the motion of a Tortoise to raise or lower the magnet as well.
The Kadee caboose trucks with electrical pick up are not as free rolling as the normal kadee trucks.
I have struggled with my cabooses for years. All my cabooses in the Fleet of Nonsense are brass. Kadee trucks could make them short out on curves if the journal boxes contacted the steps.
I tried using Tichy plastic caboose trucks with Intermountain steel wheels, but these rolled so freely, that accidental uncouplings of the caboose were common.
I switched these to the plastic Tichy wheels, but still had some issues.
I tried to make axle brakes out of phosphor bronze stirps, but could not get the adjustment to where I was happy.
When I was in N scale, kadee made springs to restain the caboose truck axles, but there is not a similar product in their HO scale line.
I plan to use these on mainline trackage and in a couple of strategic areas. I would love to activate them
I’ll second Ed’s suggestion on the electromagnetic Kadee’s. I had the same issue, routine mainline uncoupling. I had installed 3-pair vertical cylinder magnets, but the same issue. I decided to try the electro’s and am glad I did. It is a bit of a project, but a satisfying one.
it looks like a controllable uncoupler can be made if two magnets are mounted on a plate directly under the track that can be manually rotated with a push rod.
I also use the Kadee Electro Magnetic Uncoulers in pairs like Paul. As he said it’s a bit of work to install them and they take a chunk of power to operate them but they work GREAT!
I use mini toggles on my control panel and the originals didn’t last very long. I ended up using relays to switch the current, I didn’t want large toggles on my panel.
EDIT:
I made a couple of moving magnets and they also work good, the post on my had blog disappered when I went to link to it. I did a redo of it as close as I could remember. For those interested in seeing what Mel the dingbat trainguy does when he is stuck at the workbench check it out:
I fought this problem from the start and finally gave up and removed the uncouplers from the mainline and only use them on sidings, spurs, and yards. To uncouple on the main, I use bamboo skewers which are cheap. I quickly got the hang of uncoupling manually with the skewers. Kadee makes a tool for doing this and in a pinch you can use a small flathead screwdriver.
Kadee does make electro-magnetic uncouplers that only uncouple when they are turned on. That’s fairly expensive and they are quite bulking. In my case, it was not practical to put one at all the places I would need one for both trailing and facing point spurs.
I insert one of the Kadee knuckle springs in the axle pocket in a truck of my cabooses (cabeese). This creates enough drag to keep the cars from going slack.
I twice posted a way to make and install permanent magnet uncouplers in a layout below the track that can be left in a lower position, raised when you want them. They work extremely well, never an unwanted uncoupling. Invisible on the layout.
I got only one comment, saying something like they look cheap. (unlike bamboo skewers?) Dan
Great discussion topic. Is there a difference between using electromagnetic coupling devices on the mainline than yard/sidings?
I’m planning on putting some in the throat of a yard. On the 1st layout, I used a metal sheet with small cylinder-shaped magnets. Think that the OP could use them on the mainline? I forgot who made them. Kaddee?
The Rapido uncoupler basically works like that. Works very well. In all cases, coupling and uncoupling at command works better when using KD couplers, installed at the proper height, well lubricated and on a flat surface.
This is a design of using Kadee permanent magnet a friend of mine designed some times ago
It’s cost nearly nothing, works great and undesired uncoupling over them are gone for ever
In fact Rapido use a similar way except they concealed two magnet in a box.
Our design is manualy operated, but could be easily powered with a servo or an Hankscraft display motor.
Then years ago, a good friend of me, was in the way to install permanent Kadee Magnet uncoupler on his layout.
He made a mistake when putting one in place, but this mistake was in fact like an “EUREKA”.
The magnet does’nt work, and after a few observation, the conclusion was so idiot, just before us !
You can imagine how it’s simple, and after this mistake we have speak a lot about this so idiot way to use magnet, we never understand who it’s possible such so simply trick was never used or proposed for a permanent uncoupler for Kadee couplers or clones.
When you put a Kadee magnet in the normal position under the track, the couplers which comes over the magnet uncouple, we all know it, the only trouble about permanent magnet is when a train is passing over the magnet, sometimes a car uncouple even if you are not asking to uncouple.
Get yourself two 1/8 diameter cylinder neodymium magnets. Drill two holes side by side just inside the rails. Jam one magnet with the north pole up in one hole and the south pole up in the other.
The field is strong enough to uncouple precisely spotted cars, but small enough that your moving train will be in and out of the field before the couplers can disengage from the slack.
