Just finished watching part of a video sent to me by MR. It has the table surface made from birch plywood topped with construction foam sheets. That being the case, I have some questions:
One of the stated purposes of the cork roadbed is “quiet operation”. But do you use it on top of the foam as well? Is this overkill?
Is there a covering (material, paint,etc.) of any kind put on top of the foam sheets first?
If you do, in fact, use the cork roadbed, I would assume that it is glued in place on the foam. So, what type of glue is best?
If I’m going to go as stated above, then how is the track itself attached? More glue? Nails or brads? I am thinking that any type of nail or brad is now going only into cork and/or foam (as opposed to into the plywood). Is that enough to hold it?
Finally, I’d appreciate all suggestions on ballast. Material to use, method of application, etc. This is something I have never done.
Thanks everyone!
