Question re assembly of rolling stock underframes
The following would perhaps best be answered by someone with experience in RR carbuilding, either at a car manufacturer or at a RR company shop doing major rebuilds of freight cars.
I’m wondering if prototype freight car underframes are assembled/worked on “upside down” during their manufacture. I remember EMD assembling diesel loco chassis this way, then rotating the chassis right side up to install the equipment (prime move, generator, etc) on top of the floor. But was this done in building rolling stock?
This question arises because many prototype underframe engineering drawings are top plan views, looking down with floor removed. Unfortunately, some people who make drawings for modeling purposes don’t realize this, and the magazine editors don’t catch this either. The result is published drawings in hobby magazines that show underframes reversed, because in modeling, we look at car underbodies upside down.
This has happened most recently with Lionel’s O Gauge milk cars introduced in Sept 2002 & currently being re-issued, and I’m told it is common with Athearn HO freight cars also.
Comments from knowledgeable people with industry experience will be much appreciated. Thank you.
I remember a Tracks Ahead episode where it showed metra cars in a shop where the people would work underneath the car . they had a pit underneath it to work on them.Very interesting.
stay safe
joe
I can’t comment on models – no experience there.
Every photograph I’ve seen of freight car manufacture of the wood-frame era shows the car being assembled right-side-up. There is very little underneath the car–just the brake equipment (the truss rods are part of the structure)–and while overhead work is inefficient and slow, the amount of it was apparently deemed less expensive than to purchase cranes or fixtures that could rotate the frame after all the parts were added. In this era labor was cheap, machines expensive.
The photos I’ve seen of car assembly using cast-steel underframes appear to follow the same practice.
When freight cars moved into the fabricated steel underframes era, however, upside-down assembly took on a new aspect: welding overhead is something to be avoided whenever possible because the weld quality is very difficult to maintain. But most of these frames can be assembled by reaching through and there’s no advantage in an upside-down frame, assuming one is then applying a wood floor. I’ve seen photos of car assembly in the 1940s and 1950s showing frames being assembled both upside down and right side up; the general practice in either case seems to be to get the frame onto trucks as soon as possible in order to move the car down the assembly line with little effort.
Modern steel cars in every case I’ve seen use a rotating fixture, not so much for the addition of brake gear–though that is made more efficient–but to lower the cost of welding and to obtain consistent high-quality welds.
Transit cars are assembled right side up, even though there’s a great deal of equipment, piping, and wiring beneath them. We toured the Siemens shop in South Sacramento last year and observed this. I asked about it and the shift foreman conceded it would be more efficient to do the underfloor work with the car flipped over, but then they would have to build fixtures for this, and given the small production runs and variations in car le
stay safe
joe
