question regarding curve requirements for engines
Thanks for that I appreciate your understanding even though i posted in the wrong section, I am surprised that such a tiny train needs such a huge amount of room to turn around, I think Id better make a 60 inch diameter circle for my track to do it properly. Thanks Ill go & post in the correct section next time.
Good luck with your G scale it really does sound fascinating.
Regards Tim
Your question is about minamum radious for engin’s But if you use a critter or a lady bug you can run at 4’ radious with short car’s. If you intend to run any of the newer passenger car’s then you will need to use as large a diamiter track as possable.
