Hello All:
Recently aquired a PW 623 from a show and the body looks exceptionaly good for its age. In looking at pictures on line I observed that there is a GM decal on some units on the side of the engine body, lower left corner. Was this standard on all engines, because some units on ebay do not have this decal? My engine has the 10 siderail attachment points instead of the 3 that later year models had. Thus, mine might be a 1952 version, or another words an early model. My question is if the GM decal is standard on all PW 623’s or not, because my unit has no such decal? I’m trying to determine if mine is a repainted unit or not?
Also, I’m looking at purchasing a Pre War 259E from a friend. There is no e-unit on this engine, just a forward and reverse switch that one has access to from inside the back of the cab. There is a vertical slot inside the back of the cab wall and there is a metal handle through this slot that one can manually change the direction of the engine. On the top of the engine there also is a slot for a standard e- unit handle to exit from, but of course none present. My question is if these engines all came with a functional e- unit and this particular engine is a rebuild without an e- unit, or were some produced without an e unit, just a forward reverse switch? Again, I’m trying to determine if this is an original engine or a reworked one without original standard parts?
Thanks for your expertise and sharing it.
Mickey
