Quick Photo Backdrop for Digital Images
Not that I am a great photographer or anything, but I have been inventorying my “vast” accumulation of RTR, BB and flea market impulse purchases to post onto the Yard Office software>In addition to data and notes about each item, I also wanted to include a photo of each.
I came up with a quick and easy neutral backdrop for taking pictures:
  1. For HO, cut 2 pieces of 3/16" thick foam core board (Elmers at Walmart or similar) into 18" x 4" panels. (this may vary larger or smaller for other scales, obviously- that goes for camera distance, etc. as well)
  2. Use a piece of blue painting masking tape to leave a 3/16" gluing area along one edge of one of the pieces and glue both pieces at 90 degrees. I used contact cement, but white glue will also work.
  3. Push straight pins into the underside where the two pieces meet, from underneath the base up into the vertical piece every 2 inches or so- also at each end. (I do this with my students’ architectural models to aid in glue-ups and also to preserve intersection strength).
Voila! - as my daughter, the French language student, would say.
The white backround is excellent for photos. Set it on a table and use a tripod with your camera to take photos from about 3 to 4 feet away (this might vary as you focus on different sized objects).
Use MS Picture Manager to rotate,if needed, slightly (usually 1 degree up or down), then crop the image just past the coupler hose on each end of the car/loco, crop down to about 1/8" above the highest point on the car/loco and just below the bottom of the wheel arcs. (this eliminates the base of the backdrop showing in the final image). The resulting final image will be a clean, sharp one. (that’s why I use a tripod!!!)
The size of this backdrop handles A+B diesel
An afterthought:
What got me thinking about this idea was the poor quality of many images of model railroad items offered for sale I see on E-Bay when I shop the listings- people put them on linoleum floors, outside with the blurred family dog in the background, etc.
Cedarwoodron
