Bought 2 PRR R50b cars on eBay. Neither one has the handrail package and Walthers doesn’t have them available. What size brass wire and what size drill will I need to install my own? thank you
.008" wire would probably be the correct scale size wire to use. I usually use .010" because many details on models are molded oversized, and the larger wire is more in line with keeping the proportions equal. Many commercial grab irons use .012" wire.
A #80 drill will work for any of them.
Mark
I’ll have to look at some of mine later tonight. One thing I really regret is not marking the little plastic bags to correspond with each car. I ‘should’ have some grab irons that I can measure for you and if I take a proper inventory I may have some to spare.
I seem to recall one of the end grabs is bent into a vee shape.
Regards, Ed
thank you
Ed, the ones with the V are probably from the B60b baggage car.
