hello I’m french.
With a radio control on board my locomotiv can run on a DC control if I would for an exemple on my freind layout?
A radio control useDC or AC power? If I can use the two power what is the best?
hello I’m french.
The “Aristo Craft On board Train Enginere” can be ran off of batteries or Track power.
Both modes are radio controle.
I believe that all G scale RC is DC. corect me if im wrong.
Sincerely
Philip
Philip,
Like most other battery R/C systems, when a trackside TE is to be used on board a loco and be powered by a constant voltage on the track, you must fit a bridge rectifier with suitable filtering between the track pick ups and the TE itself. Otherwise when the loco is running the opposite way it cannot pick up power.
With a bridge rectifier in the loco on the track pick ups it will not matter if the constant track power is AC or DC.
