Now you start to get the picture of why railroaders get VERY concerned about tiny nicks in the rail, hate anything with cat-tracks and flip out over lowboy semi trucks getting hung up at crossings.
Works pretty much on the same principle as a glass cutter - ‘score’ the head of the rail with the cutter to cause a ‘stress concentration’ there to start the break/ cut, and maybe the web and the base, too, to control the break line there as well. Prop the rail at the cut line over something solid to serve as a fulcrum, and whack the ‘free end’ with a heavy hammer, and you should get a pretty clean cut . . . [:-^] They probably worked pretty well back in the day of comparatively brittle and light 60 to 85 and maybe 100 lb. rails - note that the linked plan is dated May 1920, last revised Jan. 1931 - but I sure wouldn’t want to try to cut/ break one of today’s tough and tempered 141-RE rails with one !
Where I used to work there was usually 1 or 2 around in each tool truck and trailer, but I don’t believe I ever saw one used. We had enough rail saws - first the gas-engine powered reciprocating hacksaw type, then the gas-powered abrasive wheel type - that there was no need to get the old rail cutters out. Especially since each crew also had a ‘hot saw’ with them - the oxygen-acetylene cutting torch outfit. (I know, I know - those are not to be used on main line rails, and often not on industrial tracks either - but sometimes an expedient was needed in an ‘emergency’ situation to patch the tracks together after a derailment, or pending more permanent repairs, etc. Also, such things as the middle ‘hold-down’ rails under the Hayes bumpers,and the last rail of a track - how those were cut to length really didn’t matter, since they would never carry a
Further on thise - I note that the specs for the PRR’s Rail Cutter mention that the test rails should have a Brinell Hardness Number of about 260. However, I believe - but am not certain - that current rails have a BHN in the 340 range, so that today’s rails are considerably harder and tougher now.
From this webpage - http://cprr.org/Museum/Caliron/ = Central Pacific Railroad Photographic History Museum - California Iron from the G. J. Graves Collection, under the heading of Rail Chisels from the WPRR, SP Co., and CPRR, about 3/4 of the way down, which includes some photos:
“The unmarked Central Pacific rusted rail chisel (right) is very close in shape to a spike hammer. Marked Southern Pacific (middle) and Western Pacific Railroad (left) rail chisels are also shown. These chisels are used to cut the rail to the desired length. One hit the chisel with a sledge, all around the rail, cutting into it 1/4 inch or so. Then the worker would jam a steel rod into the cut, and bang on it until the rail broke.”
We use old rail for grizzly bars over our feed hoppers but we don’t run trains on them just rock. I never tried to score and snap it. The torch is fast and clean. Maybe when I get some time I will try the score and snap method on some of the old rail we have in the stock rack. Those MW guys worked their butts off back then. Guys now a days can not work like some of us old timers. When we do a steel change in a crusher out comes the 20 lb. hammers. Most of the time it is swung like a base ball bat and I can get a good 9 or 10 reps before I need a break. Some of these young guys can’t hit what their swinging at and snapping handles and ricocheting off other parts. It appears swinging the big hammer is becoming a lost art.
That is a great site. The PRR had standards for everything. Even brooms.
