In a previous post, ‘joe-daddy’ provided some excellent information on the differences between Code 83 rail from Peco and Code 83 from Atlas. The pics on his blog really illustrated the difference in rail height, thus resulting in some necessary filing or shimming.
My question is, how does Peco C83 marry up with C83 Shinohara? Are they a pretty close match, or are there subtle rail height differences between these two brands, as with the Peco/Atlas combination?
Current production Walthers (made by Shinohara) c83 rail is the same height and web design as Atlas. With the Peco/ME the diff is in the width of the lower web. If an I represents a rail, I am talking about the width of the bottom _ not the height. That width difference screws up the joiner technology and requires the transitioning.
Back to Walthers/Shinohara(W/S) the Ties are about .020 different between C83 W/S and Atlas 83. They will join smoothly, but you haveshouldto shim up the turnout slightly. With C83 W/S and Peco you still have the problem of the lower web of the Peco being too narrow PLUS the tie height difference, making it a double foul in my mind.
So far as I can tell, Peco and ME are compatible with each other in C83.
This why I have retreated to using Atlas c83 with Atlas c83 Mark4 turnouts.
Another thing to be aware of as it affects the effectiveness of rail joiners is the base flange width varies between track manufacturers. One glaring difference is MicroEngineering track is a lot narrower base than Walthers Shinohara. It is very difficult to join them with Micro’s joiners.
