I got my BS-EECS from UC Bezerkeley in '76 and MSNE in '78. Had an interesting time in the lower division Materials Science class - lots of interesting stuff, though some of my EE classmates complained about having to learn the ins and outs of concrete. It was also amusing to note that one of the authors of the textbook used for the course, Craig Barret, went on to head Intel.
As far as rail heating - the heating will come from the inelastic bending of the steel (the hysteresis that Paul mentioned). The upper limit for rail heating an be estimated from rolling resistance - the heat losses from rolling resistance will be distributed among rail heating, wheel heating, journal bearing heating, etc.
Edit: Did some numbers off the top of my head, looks like the thermometer would have to be pretty sensitive to measure the temperature rise on stiff straight track - on the order of 0.1 degree F (or less) for a 10,000 ton train. Temperature rise for curved track would be higher due to increased wheel-rail friction losses.
Those pennies are being heated up by the flattening/deformation.
You can demonstrate the same effect by taking a paperclip and bending it back-and-forth until it breaks. The ends will be warm (even uncomfortably hot, if you did it quick-enough). The heat energy comes from the mechanical work you did in the bending; while a large fraction of said work goes into rearranging the atomic structure of the paperclip (or penny), a portion is turned into “heat” (i.e., vibrations of the atoms in-place).
Note that the pennies never really stop deforming as each subsequent car runs over them; it’s just that in each case, they have already been spread out/deformed, and subsequent deformations will have less material at any instant to flatten out further (only the material at the contact point between the rail and the wheel is being flattened out). Eventually, if the coin stays in place long-enough (perhaps several trains), it will
After getting what I thought was a useless degree and working in the broadcasting biz for a few years, I came back down from Hollyweird to SUDS (or SDSU) and did a BSEE about 30 years ago, then moved out to UCSD for grad school, then into defense contracting because I had educated myself out of show biz, though that was still the most fun part of life.
I suspect, based only on engineering experience and such, that rail heating due to the bending process is probably insignificant, even with respect to flange action. I am not curious enough to take an IR thermometer and do before and after measurements; we don’t have trains long enough or heavy enough down here to be interesting anyway.
