Rapido GP9rm can I put a Bluenami decoder in it?
I am coming back after 20 years away, former DC N scale.
I’m going to do HO. I purchased a Rapido 41004 GP9rm (Silent DC Only) yesterday thinking I could get a bluenami decoder and install.
  • Was I wrong? Can I plug a Bluenami decoder into the 21 pin?
  • I thought it would have a speaker – I guess I’m wrong there and will need to add a speaker if I wish to have sound?
Any help is appreciated as I’m a little out of my element with wiring/electronics, etc.
Thank you in advance!
You can plug any 21-pin decoder into the 21-pin receptacle and run the engine. However, the lighting effects etc. apparently are pre-mapped for ESU decoders. Just means if you install a Blunami, you will need to adjust some CVs to get all the lighting effects to work the way you want.
You would need to add a speaker / enclosure if there isn’t one.The literature that came with the engine (like an ‘exploded diagram’) should show where to attach it.
Welcome aboard @ToddF
Thanks for your info!
wjstix
Actually, it means that some of the lighting functions may not work, period. Just a cautionary reminder about replacing ESU decoders on ESU motherboards with another brand decoder …
