I have a vintage Japanese made engine, powered by a Pittman open frame motor. To make a long story short, my plan is to replace the complete drive system with two NWSL spud trucks. My question, do I treat
the two individual power trucks as two separate engines and then mu so this can be run by dcc?
I would appreciate some guidance as to what is the best way to approach this.
You an also email Dave at NWSL He has done an all metal old HO MDC 4-4-2 for me which had a Pittman motor. He re-geared and re-motored for me. He does answer email as I have corresponded with him before. He would have suggestions on what to use. I could have done this with parts from him but was pressed for time.
If your engine is big enough to have an open frame Pittman, you should consider a can motor. The Spud design has been around for decades. I’m not certain how DCC friendly it is. That aside why go thru hassle of wiring two motors when one would do the job.
My take on this is that (a) I have the trucks, (b) the factory trucks are of such age ( cast zinc, some fiber gears) that to refurbish them may not be at all possible. However I appreciate the tip to contact NWSL.
I have seen the little power trucks peel the teeth from the gears when over loaded with either weight or a heavy train.
I have a vintage open frame steamer that I tuned up with replacing the magnet with super magnets. It brought the amp draw from 1.2 amps to under a 1/2 amp. It runs very good for a fifty three year old loco. When I have the extra $$ I will replace the non sound decoder with a Loksound micro.
Since Mr Sagami (maker of the NWSL motors) retired a couple of years ago, NWSL has designed all new motors and spud drives, they are now called Stanton motors and drives and are excellent. However, the new spud trucks are quite expensive $80.00 retail per truck, so $160 per loco. They are wired in parallel, not as separate engines for DC or DCC operation. As separate engines you would only have 4-wheel pickup, in parallel you douple the pickup and reliabillity.
I’m inclined to agree with the others, replace the old motor with a new can motor. What is the locomotive specifically? There may be other options, such as adapting a modern plastic loco’s drive and trucks to the brass chassis, we do it all the time. Or as already has been mentioned get a hold of NWSL, he will certainly give you solid advice.
Sorry Gent’s, I guess when a person is too close to a situation the obvious is
not explained. In actuality my feeling is the power truck and the driven truck are both at the end of useful life stage. This is why the desire to use Spud trucks. Thanks again for each suggestion and opinion.
Specifically, what engine do you have. Who is the maker? I custom painted brass for over 12 years and have had just about everything under the sun apart. I have also remotored and/or regeared around 50 brass locos. If the power trucks are of the age that have the old style gear towers with the exposed gears, they are generally awful. The original ALCO brand Locos were pretty good to look at, but sounded like coffee grinders. Every once in a while you might luck out and get one that actually runs fairly decently. If so, definitely replace the motor with a can.
A SPUD powered decoder conversion was one of my very first decoder conversions. At the time the reason for the SPUDs were that the decoders were so large (about the size of Rhode Island) that I needed lots of the space in the loco just for it. The SPUDs do have can motors in them so the current is low. I think current was less than 500 ma. for both. I connected both the SPUDs to the single decoder. I also loaded the rest of the loco shell with lead. I was never able to find the “stall” current on the SPUDs because I could not get them to stall. It would have taken a block of lead.
As I recall the hardest part was opening the SPUD to isolate the track power from the motor. I think I used the existing wires for the track power and added new wires for the motor.
Second Thought. Now that I think about it… I also did a SPUD conversion that was an F7AB set with three SPUDS. Both trucks in the B unit and the rear in the A unit. I connected all three SPUDs to a single decoder. This configuration didn’t last long because I found one of the SPUDs was turning at a different speed than the other two and fighting against each other instead of pulling together. I moved the two that matched onto one unit, and never got back to fix the third. The A unit is still a dummy that gets pushed around by the B unit.
I ordered enough magnets for at least 3 motors from K&J magnets and it was only about $12 with shipping. My open frame motors run great and the torque output from them is better than a can of comparable size.
Tenshodo GP7 - First ‘narrow’ hood GP that I am aware of - Was in rather short production by PFM.
Good Points
The basic drive is bullet-proof. A little noisy, but not too bad.
Bad Points
The Pittman ‘clone’ motor is the weak point. Lots of current draw, and the magnet loses strength over time. A ‘re-motor’ is a good option.
The electrical pick-up. Typical early design - pick up off of the right front truck, return off of the rear left truck - Not all wheel electrical pick up. Not a good candidate for DCC/Sound decoders.
Truck wheel base - way too short - Tenshodo used the FT wheel base and it shows - The trucks are too far inboard when viewed.
Your idea of using NWSL ‘Stanton’ drives is good - You will need to adjust the truck mounting to fix that too short overall wheel base. The problem is that you are sinking a lot of money/work into a model that really only has sentimental value. If you are looking for a good running GP7 - Atlas, P2K, and Atherarn Genesis may be far better for accuracy/detail/running qualities.
Easier option than remotoring - super magnets. You can get them lots of places, but Micro Mark sells a set for motor magnet replacement - these magnets repalce old weak and tired magnets and result in a smoother, cooler running motor that often draws far less current than the original one did. If the rest of the drive is good, there’s no reason to mess with it.
