Re-Using Chooch Enterprises Flexible Stone Walls
Chooch Enterprises makes Flexible Stone Walls which have an adhesive backed surface that sticks nicely on wood surfaces.
Now I want to re-use these Flexible Stone Walls on a different wood surface. They peel off the original wood surface nicely, but are not sticking well to the new wood surface.
I have thought about using Elmers Rubber Cement or Walthers Goo, but I thought that I would check here first.
Has anyone re-used these Flexible Stone Walls? What type of adhesive did you use?
I’d try some white double-sided foam tape instead of a liquid adhesive.
I would stay away from the double sided foam tape, that stuff always makes a mess when you try to remove it. Why not try some adhesive silicone caulk, it’s good enough to lay track with, it should work fine for this too.
Thanks for all of the suggestions, guys.
I called Mike, the owner, at Chooch Enterprises yesterday, and he said that they have had good experience with CA adhesive. So, I tried it on a sample with good results. Next, I will use it to re-install the flexible stone walls.
