can a model be re washed after it has been painted with model flex primer with dish soap if it has been handled by hand?rambo1…
Easy answer, yes. However, don’t use the concentrated “anti-bacterial” type soaps that contain lanolin and other moisturizers. You can use Dawn (plain) or original Ivory liquid. You only need a drop.
Before washing, allow it sufficient cure time. If you wash it prematurely the primer, being water based, will wash off. [^o)]
Curious: Were not your hands clean when you handled the shell? I normally use latex gloves because my hands become a little moist as I work on projects. But in the past when I’ve run out of gloves I always washed my hands and dried them thoroughly.
no probably my hands were’t clean thats why I thought it should be washed again but I used the wrong soap.I’ll try again with the right stuff.rambo1…
