Really old stuff still on your layout
Ok, this may be crazy, but does anyone remember the wooden milled roadbed from the 40’s?- 50’s that you hand laid rail into and does anyone still have it. On second thought how far back does things go that are on your layout?
This Athearn Geep is probably about 30 years old. It received a detail and paint job over 20 years ago along with a can motor, and later got new trucks. I recently found it in a box and repaired it, plus I dropped a DCC decoder in it to run along with my newer locos.
708 Roster
Sounds like Tru-Scale track. I believe the product was still being manufactured as late as the 1980s. I thought I read on another post that it is no longer being made although somebody might still have some stock available.
This old Athearn Geep is at least 50.
It was originally a rubber-band drive unit. Now, the motor and drive belts are gone, and it runs as a sound-equipped dummy engine. This Suydam cardboard Swift plant model is even older. I got it used back in the 1950s. I have no idea when it was built.
I have some really old equipment on my layout such as this all metal Athearn 250 ton crane made about 1951, and this old brass Baldwin AS616 diesel made back in the 1970s. I added a can motor in the diesel and had painted it myself. The Athearn Crane is so heavy you can see that it can hold the diesel up off the track. I think there were some really well made models back then.
You are talking about the old Tru-Scale track. Still have a short piece for wheel cleaning for my motive power.
I still have some of that old Tru-Scale self gauging roadbed as well as plain roadbed unused. I bought some from a hobby store clearance sale and never got around to using it.
It’s still available here http://www.troutcreekeng.com/bkho.html but I think it’s only the plain roadbed.
Although I changed scales from HO, I still have several boxes of stuff from the 70’s. Don’t have an HO layout currently, but I may set up a display layout just to show the old stuff.
Enjoy
Paul
At Boothbay Railway Village, we get a number of donations of old equipment, some work and some do not. This Seaboard 13567 outside braced boxcar has cast metal sides, roof and doors with a wood floor and came with sprung metal trucks. It is either Roundhouse or Varney dating from the early to mid 1950s. We added Kadee couplers and had to reppace the trucks because they were too worn out. The wheelsets would just fall out. We run the car often when the museum is open during the summer.
We also have a couple of transformers (today we call them power packs) dating from the 1920s. One is a Lionel. We have done continuity tests and the wiring is complete, but do not dare to plug them in because the insulation is too old.
The station at Dove Creek is the oldest item on my layout. I built it when dad was stationed in Germany with the AF. It won first place in the railroad model youth category in 1972 in a model show for military personnel and their dependents.
I built it according to the plan for “Small Town Station” by Joe Wilhelm on page 5 in Kalmbach’s classic “Easy-to-Build Model Railroad Structures,” edited by Willard V. Anderson. Pretty much as close to scratch as you can get. The battens were each cut and applied separately, for instance.
So this structure has a lot of miles on it. It’s been on three different layouts. Currently it serves as Dove Creek’s station on the lower, standard gauge line on my Four Corners Division of the D&RGW just before it disappears to run into staging.
The rolling stock shown below is all from 1957 or '58. Most of it has been upgraded with better details and new paint.
Varney hopper:
Varney metal boxcar:
Varney tank car:
This cast metal depressed centre flatcar is from Authenticast:
This loco, by John English, came into my possession at the same time, but was not new - I’d guess that it dates from the early '50s. She’s been cosmetically made-over several times, and is currently in the shop for another facelift. It has valve gear from Central Valley and a scratchbuilt tender, while the vestibule cab is from Kemtron… Still powered by her original open-frame motor, she’s a strong puller and an exceptionally smooth runner.
I don’t know, is 30’ish - 40’ish old? Today I’m running these two 70’s era Atlas GP40’s. Oh I know what’s going on inside your head right now. Your eyes are seeing the shells and are telling your brain those are 21st century Bachmann’s. Well, yes, the shells are. The chassis beneath them are old Roco/Atlas right down to the original 5-pole motors. Look closely and you can see where the notch on the fuel tank has been filled in and the trucks should be a dead giveaway. Both are DCC and are permanently mu’d. I put the Bachmann shells on them because they didn’t have any pieces missing and the detail is better.
I also have these two Atlas FP7A’s. The ex-PRR unit is a 70’s era Roco/Atlas model and the ex-UP unit is an 80’s era Roco/Con-Cor model. The second one tends to run a little hot. Probably because the metal frame is smaller and most of the motor casing is plastic. Both are DCC and permanently mu’d.
I have other antiques I run but they’re not on the layout at the moment.
Wayne,
I really like how the metal sides on the Varney boxcar show authentic looking dents. Can’t do that with plastic.
LION did have some old Atlas brass flex track with fiber ties, and also some of those old custom line switches. These were all torn out when I got rid of the staging tracks and replaced them with a new four track mane lion.
But here is a piece of equipment, a 1 rpm timer used to start trains from the various stations around the layout. There are four 5 second pulses fifteen seconds apart. The timer made by GE at least 50 maybe as much as 70 years ago was procured by Br. John when I asked him for a 1 rpm motor. Since it already had the switches as part of the unit it was perfect.
Here is a mock up of a proposed intermodal facility with a Cox 30 Ton crane that is still in great condition as the centerpiece. Lurking in the upper right is a Tyco truck loader / un-loader that came with a flat car, two trailers, a tractor and a loading and unloading ramp.
Here are two old Athearn F7 Super powered units traveling on the shelf portion of my layout . The track is old Atlas flex track with fiber ties attached with metal staple.
A great many of my steamers are older brass, some dating from about 1964. Here’s one of my 3 Akane Yellowstones that date from that year: Still with it’s original open-frame motor, but the magnet replaced with Rare Earth types. It crawls and will haul anything you want to put behind it.
I also have a fleet of the old Athearn metal cars that date from the late 'fifties, when I first got started with HO. Here’s a couple:
I have squirrel blood–if it runs, I’ll keep it, LOL!
LOL, I was wondering what in the world am I keeping this stuff for. I have quite a bit of it, even the lengths of brass rail, some unused. If you are using it and want it let me know email. I even have some turnouts, now that stuff is old from 30’s to 40’s I believe. It’s all in good shape! Jim
[quote user=“EmpireStateJR”]
!http://4.bp.blogspot.com/-Jm_w-_TxdJw/Ttu986HgZ5I/AAAAAAAAAGs/qnOIVFnJemY/s400/DSC02069.JPG
!http://1.bp.blogspot.com/-xFxyGRGH-pQ/Ttu-SYz75VI/AAAAAAAAAG0/vqsI9ZunQPw/s400/DSC02079.JPG
I have a couple of MRC power packs that I use for accessories, the oldest dates back to maybe 1980 or so. Although not currently on the layout I do still have several c.1971 Tyco freight cars that I bought from ebay a while back; they’re some of the same cars that came with my 1971 Tyco train set when I was 13 that got me started in model railroading ( and were later sold to a friend ). At some point I’ll probably convert them to Kadee’s and use them “just for fun” once in a while.
This is my original consist, a Christmas gift from my parents some time back in the mid-70’s. All still on the active roster. Can’t say it’s “really old,” because that would also make me “really old,” too.
How about the guy standing next to it operating the throttle? [:D]
Seriously (this is a GOOD photo for me, so pardon the image):
The Stephenson’s Rocket on the right was a Triang Hornby model from 1968. It blew up about a year ago, and needs a total overhaul / rebuild. The 0-4-0T is a Mantua loco purchased in 1970. Still shoves cars around on my son’s layout.
The Clever cardstock structures shown here date from the same era (late '60’s, early '70’s):
I have one fo those Tri-ang Rockets too, but I don’t run it. The deep flanges don;t work on code 83 track and I haven’t figured out how to put DCC in it. Referencing another thread - I still have the original box it came it, too. Along with the cars for it.
It was my grandfather’s, I remember running it on his layout when I was little. When he passed there were two things I wanted, that train and the old 50’s mower we dug out o his shed one year and got running.
