Reboxx Exxact Socket Tool
I just purchased the Reboxx truck tuner (T-100) and I have a question. The instructions indicate that you need to press the journals lightly together in order for the tool to clean out the sockets. The problem is the tool, which is supposed to be HO, is so short I have to squeeze the journals a lot just so the tool doesn’t fall out. When the journals are squeezed the ends of the journals aren’t square to the tool. This can’t be right. Also, if the opposite set of wheels is installed while I do this it falls out because the journals are spread so wide. I have all 1980’s Athearn rolling stock kits, so most of the trucks are the same and I am only changing the 33" wheel sets. Should I have bought the Micro-Mark tool instead? Any ideas? I posted this on Model Train Forums, but no luck thus far.
Glenn
[#welcome] to the forums!
I have the Micro-Mark socket tool. I’ve been told the Reboxx tool is exactly the same, but I have never actually compared them.
Yes, different truck manufacturers are different in widths. In my experience the Atlas roller bearing trucks are next to impossible to ream out, because they are too wide. My Athearn trucks are really tight. I’ve heard that Athearn friction bearing trucks and roller bearing trucks are different width. (I have no idea why)
Anyway, you will find the socket tool is one of the most used tools in your tool box.
Glenn:
I don’t know if there is a size difference between the tools but I can answer about the MicroMark tool. I have a collection of rolling stock from several manufacturers and have never experienced the problem you are having. I have had a couple of cases where I had to really try hard to open the trucks to get the tool in place.
Joe
Thanks Will. I have done 4 cars thus far. Very little has actually been cut out, but it wouldn’t take much to have a detrimental effect on the wheels performance. I am changing all my wheels to Intermountain wheel sets and the improvement if phenomenal. I can’t believe the difference in the weight between 2 plastic and 2 metal wheel sets. The size of the needle bearings, alone, on the Intermountain wheel sets would make a difference even without the socket tool. They are considerably smaller than those included in the kit wheel sets. I guess the bottom line is the tool certainly doesn’t appear to cause any problems, but I am still uncomfortable with the fact that the journals are not square, to the tool, when squeezed.
Thanks, Glenn
When in our old HO modular club, purchased two Reboxx Exxact-Socket tools; one for club and one for yours truly. Both worked Great on all our cars. You might e-mail Reboxx for technical advice www.reboxx.com and see what they say about your problem. Don’t know anything about Micro Mark unit but do know that Reboxx was selling their tool long before M M did…papasmurf
Maybe the TOOL is trying to tell you something!
Like - the trucks are wide enough and DO NOT need and reaming!
I have yet to find a set of trucks in ALL my years that were too tight!
MOST were TOO LOOSE !
BOB H - Clarion, PA
It’s not about makign them wider, it’s about removing molding flash that interferes with smooth rolling. I only use the tool on axles that don;t roll well - I put the wheelsets in, give them a spin - if they stop quickly, out come the wheelsets and in goes the tool, then flip the tool to do the other side. Repalce wheelset - HUGE difference. It really does work. I have tons of Athearn hopper car kits and none of them needed too much squeezing to get the tool to make contact. It does require a little squeezing. You’re makign it sound liek the tool would just fall out if you didn;t squeeze the sideframes in - I’ve NEVER had anything like that. Certainly in some brands the tool will just spin around and not possibly cut anythign without pressure, but never so loose that it would just fall out.
Thanks, Glenn
Randy and All,
Thanks for the replies. Randy, everything you said is correct. And yes the tool does fall out. It is actually shorter than the space between the side frames and couldn’t possibly stay in without squeezing. I understand it won’t remove much, but I am concerned about how “cleaning” out the sockets will affect the rolling if the tool is not square with the side frames.
papasmurf, I plan to contact Reboxx when I return home from vacation.
Nice to see so many replies from PA.
Glenn
As I said - my side frames are usually too wide - the older cars i have!
The newer trucks seem a lot better.
I must be lucky as I have never needed the tool and i have over 1000 cars on the layout and none of the Clubs cars ever needed any work on them.
We run just about every car manufactured and no trouble.
The tool WILL make the openings wider if only slightly but it will cut out the depth as it is making the taper. - something I don’t need>
BOB H - Clarion, PA
Guarantee I can demonstrate the effectiveness of this tool to you, Bob. Athearn, particularly the later runs of Blue Box kits (molds getting old), and Accurrail seem to need the most cleaning up, but even that is maybe 50%. Not all by a long shot.
Not sure even which version mine is, I bought it from a seller at a train show who carries lots of tools. although I suspect they are all the same. I’ve just never seen this too wide condition, every truck I use the tool in, I have to pry the sides apart to insert it, just like putting in a wheelset. Sometimes ir rides very loose unless i gently squeeze the sideframes, but never have I had it just fall out. That’s Athearn, Atlas, Accurrail, Branchline, Proto 2000, Stewart, and the odd T-M car or two.
Randy
While what you say may be true -
I do not need to have all my cars THAT free rolling!
Not every siding on my layout is DEAD LEVEL.
So I have had to place grass tuffs between the rails to hold the cars.
And besides - I like to have a reason to NEED more than one engine pulling a train!
I just put 10 new Accurail cars on the layout and the wheels rolled just fine. I have found some trucks that roll a little slower and to correct these I just take the side frames and spread them apart a little
This usually loosens them up enough. And if it doesn’t I just run them for a few OPs Sessions and the wheels sets will be cutting up into the side frames!
What I have been finding is that the axles on the older cars with Plastic wheels and metal axles - the axles are wearing up into the truck side frames - CAUSING the coupler heights to vary.
This is going to present a new problem most others will seldom come across!
Changing out the Wheels Sets to Metal with Plastic axles is going to pose a problem down the road (for me at least) as the axles are going to wear right OFF - if what I have already experienced with the METAL axles wearing into the side frames!
BOB H - Clarion, PA
Glenn,
Perhaps you got one of these that’s deffective–in this case, made too short.
My Micromark is 1.0325" long. If yours is much shorter, I’d say your problem is there.
Ed
Perhaps not - the slipperly plastic used on some metal wheels with plastic axles, combined with he slippery plastic of the trucks themselves - I think this would be a longer wearing combo than metal axles in the palstic trucks. With that kind of mileage, anythign will eventually wear out. I replace all my wheels unles the car or kit comes with metal wheels, no plastic wheels are allowed on my layout - perhaps part of the reason I never have to clean my track. Club is picky too, no plastic wheels allowed there either. Will be curious to see which lasts longer, Athearn cars with Intermountain wheels (metal axle) or Athearn cars with Proto 2000 wheels (plastic axles). I’m one of the few with P2K wheels though, and I don;t get to all the shows so my cars don;t get nearly the mileage of some of the others.
I have found the Reboxx/MM tool to be of great value.
Generally, when I get a new car, I try spinning the wheelsets and time how long before they stop. Less than four-five seconds isn’t very good. Eight-ten seconds is excellent. I can ream most plastic trucks to do that with good metal-axle wheelsets. These cars do then roll very well and will drift on almost any grade. I prefer them this way because it translates almost directly to how many cars a given loco can pull up my 2.5% grades. FI, two sets of my IHC passenger cars were greatly improved by changing to metal wheels and reaming the trucks, probably increasing by 50-70% the number of them possible to pull up a grade.
Hal
Ed,
Sorry for not responding sooner, but I was away. I measured mine and it is .9441" long. It is shorter than the Micro-Mark tool and I am kicking myself because I had a choice of the Reboxx, or Micro-Mark when I bought it at my LHS. Thanks for the info. I am going to call Reboxx.
Thanks,
Glenn
