What is over heating? Assuming it is the boosters, you really need to either add a booster or two or redistribute the power you have.
Changing power supplies is not going to allow your boosters to run cooler. They are getting the 5 amps they need from your power supplies. Running hot means you are close to the limits of the booster outputs. Increasing power supply won’t increase the booster’s limits.
Make sure your boosters have plenty of free air to cool themselves.You might try a small fan to get cool air moving across their heat sinks that are on the rear of the case.
And 17 locos, unless they are all actually running, not just standing still, should stress 10 amps total of power, unless they are all collected in one area with a single 5 amps. Unless they are like that other fellow’s Bachmann sound loco that draws over half an amp sitting still - that is highly abnormal
So far, it is working well and we are pleased with its operation.
Also, you may want to place a small 8 inch fan near the back of your boosters as we have done for about 20 years. Our boosters do not overheat with this cooling method.
